![]() | Home > Technical (L322) > Supercharged Tyre question ......... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
hi mate and welcome..
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
Are you sure on the tyre size? FFRR have 255/50R20 as standard. Edit: Scarey beat me to it. ![]() |
sharpm Member Since: 08 Nov 2010 Location: Central Scotland Posts: 33 ![]() ![]() ![]() |
yes correct 50 profile as standard and ive edited my original post !!
if still under warranty then could be best to stick with the tyre size thats on at the moment, but once out of warranty then you can do what you want... ... - .- -.
Would a wider tyre aquaplane easier in the wet?
depends if you have enough grooves in the tyre ..look at f1 cars with their very wide tyres.. ... - .- -.
... Hmm, so wide is good if I change them every time it rains? |
That was why i took the 275 x 45 x 20's off and left them in the garage in the wet the car was sliding about more than Wayne Rooneys bell end in a Kellogs Frostie ...... |
possibly down to the amount of tread and make of tyre you had mick...275 is only 2 cm wider than the standard 255 size and shouldn't make a difference..
any views on the best road tyre brand to go for ?? |
stick to a well known brand and you will be ok...as for recommendations, one persons view might be different to another's... ... - .- -.
Cheers Stan |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
there is wide and there is too wide |
Should that not be 20cm stan ......... ![]() ![]() |
