![]() | Home > Maintenance & Mods (L322) > Rear wheel arches FFRR 12 |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 358 ![]() ![]() ![]() |
Re: Rear wheel arch protection / inner arch
Hi Peter
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Hi,
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 614 ![]() ![]() ![]() |
How many meter's you order ? thanks paul |
Hi Paul
Hi Peter Have a look at when the cars on the lowest suspension setting - there's not much clearance for you if you were under her !!!!! - I am sure they have a mind of their own Good luck with yours if you decide to do it - |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3317 ![]() ![]() ![]() |
These were fitted to the Freelander as standard and can be bought from Dan @ Duckworths. They're also fitted to our 2012 from the factory so should also be available.
I'm going to upgrade the rubber rear arch trims on our 2012. Theyre genuine LR/ arches are not affected by rust.
ndf's plastic strips don't seem to go out of shape like the original ones. Thanks ![]() |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
^--- +1 for @NiceDayForIt solution
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980 ![]() ![]() ![]() |
I’ve just ordered some of the plastic door edge ones. The Land Rover ones have all corroded and bent out of shape.....
