Home > Technical (L322) > L322 Wont Start, Clicking noise from behind dash
Page 2 of 3 <123>
Unfortunately it is definitely NOT the ignition switch then...
It is the steering lock which is incorporated within the steering column and can't be bought separately...
This has been a common problem in the USA, mostly in the warmer states so it seems to be a heat thing but will effect all early 2002-2005 FF's eventually.
The fix from the dealer is a new steering column but they are several thousand pounds.... Big Cry
The cheapest thing to fix it is to make up a switch and inline fuse and fit it in fuse 18's hole, several have done this and it is a permanent but inconvenient fix, every time you want to start the car you have to switch the switch off, wait about 30seconds then switch it back on and it will start... or remember to switch it off as you leave the car and then back on again when you get in (on reading that it seems to me it would be easy to fix a relay in with a self collapsing circuit and it would do it for you...)
No one has published a full repair for this, someone put up some pictures of where to drill a hole in the column and squirt in some WD40 to try to lube the plunger which is getting stuck but I have heard of lots of horror stories as the hole is very close to all the electronics and one wrong move and the column is toast....
Several people in the USA have said they can fix it but won't publish how, understandable as it's their fix....
I have an idea how to do it from trawling through the wiring diagrams and studying all the info available but it is only an idea, it would take many hours to try and is not guaranteed.
I'm not prepared to share it as it will then be in the public domain and maybe totally wrong...
My FF is showing the early signs of this and when it packs up totally I will have a go at mine, no loss as both of my steering wheel move motors are broken as well....
So the answer is a new or second hand column, they do come up on ebay but still fetch a good price as this is now getting to be a common fault along with the motors...
I believe Cam-Tech-Craig on here has had some success with fixing them (I could be totally wrong) but I don't know anyone else this side of the pond who has done it...
Sorry to be doom and gloom but at least you now know exactly what it is.... Thumbs Up Pete
-Click here for Thread-
Post #352861 18th Oct 2015 12:21pm
NeilC
2003 Range Rover Autobiography 4.4 V8 Java Black
Pete,
Thanks so much for that info, (event though its not what I really wanted to hear Sad )
I think the idea of fitting a self colapsing relay into fuse 18 is a great idea.
Im going to speak to an auto electrician I know and see if he can do this.
Ill trawel the net to try and see what a second hand column is too (may be a horror story !!)
Again thank you so much for the info and your time on a sunday
Neil
Post #352865 18th Oct 2015 12:31pm
No problem, glad to help,
I can soon do you a diagram if you want to DIY it.... very easy to do with stuff from Halfords.... Pete
Post #352867 18th Oct 2015 12:39pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
NeilC wrote:
Hi Guys,
Just fitted a new battery and the car started first time.
However i swithced it off and tried to start it again and nothing but the click click click !
Any ideas ?
Neil
When I had the problem with my car, before I replaced re battery,I could charge the battery connect and it would disengage the steering lock and start, turn it off and remove key, re insert and attempt to start and the steering lock wouldn't disengage or permit the key to turn/start.
Disconnect battery for 5 mins, refit and would start again, remove key and back to square one!
I would firstly ensure the battery is at full charge! as suggested.
I hope this is the answer or you unfortunately may have a more serious problem
Just noticed your car is a 2003, mine being a later 2008, I hope it all works out Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #352870 18th Oct 2015 12:50pm
There is an outside chance it's voltage related but I wouldn't think so as you haven't got any other faults shown and a low voltage sends everything crazy....!!! Pete
Post #352872 18th Oct 2015 12:53pm
NeilC
A diagram would be much appreciated Pete whihc you have time.
Ive pulled the fuse a couple of times and restarted the car every time, you can hear the steering lock knock off each time !
Cheapest rack I can find is £500.00, God knows how much it would cost to fit it !!
Love em ! hate em ! all at the same time
Post #352875 18th Oct 2015 1:12pm
Might just be worth disconnecting the battery, see how to do it properly in the WIKI if you haven't as it has an explosive disconnect, and then give it an overnight charge if you have a charger, just a trickle charge will do don't do it on full power or you will boil it to death....
I'll get some time in the next couple of days to sort out a diagram and show you where to plug it.... Thumbs Up Pete
Post #352878 18th Oct 2015 1:21pm
NeilC
Royston, Established its the steering rang lock with Petes help.
Same thing happens with my car, disconnect battery and it starts once then repeat !!
Post #352879 18th Oct 2015 1:24pm
Thinking about this a colapsing curcuit would work with mine as I have removed the plunger in the ignition switch so mine will always get to ignition but won't crank, you can't get to ign live so may be able to do something with a timer relay...
For now you just need a 10amp inline fuse, a switch and some spade connectors, wire the fuse and switch in line and then both free ends put a male spade connector on then plug these two ends into where the fuse goes, one spade terminal in each side of the fuse, doesn't matter which way round... Standard male spade connectors are the same size as the fuse ends.. You can make a cheap fuse holder with two female spade connectors and a blade fuse as used in the FF, just make sure you tape up the bare ends....
Something like this... you can make the wire as long as you like to get the switch over to the drivers side and stick it somewhere... the wire rating should be the same or greater than the fuse rating (Fuse 18 should be a 10amp)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #352883 18th Oct 2015 1:58pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Don´t drill the little hole in the column, your solenoid (picture attached) can be destroyed, believe me, the cheap solution is dangerous for you! The Solenoid ist not to buy, only with a whole column, you must dismantle the whole column to clean the solenoid, that is the only way. Make it often here in Germany..., best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #352885 18th Oct 2015 2:31pm
NeilC
thansk for that Pete,
Ill give the details to the spark I know and see what he can do.
Uli
I definately wont be drilling it
thanks
Neil
Post #352887 18th Oct 2015 2:42pm
Uli, Did you try it with the solenoid removed, would it still work then....??
The way I understood the "cheap fix" was that it defaulted to unlock by virtue of the spring so there was no way the column could be locked as then removing fuse 18 wouldn't work as the column was locked...!!!??? Pete
Post #352890 18th Oct 2015 2:48pm
Meerbusch
@Haylands, the solenoid has full function after cleaning with WD40, also you have to clean the white motor, he pushes the lock in and out, and the solenoid with his pin is for security, when the motor becomes crazy ...., and will close while driving Wink)
The Solenoid is german manufactured, not in production since ten years, and NOWHERE in the world to get..., searched since month....
Best rgs, Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #352896 18th Oct 2015 3:06pm
I see, thanks, I have been removing bit's of mine to make it far simpler and more reliable, the plunger that locks the ignition and the arm that locks the gearstick, wanted to remove the steering lock as JLR did with the later ones so want to know if it will work without them in place...
I thought there was a failsafe and the lock couldn't come on whilst driving...??? Pete
Post #352904 18th Oct 2015 3:36pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
@Haylands
.... "I thought there was a failsafe and the lock couldn't come on whilst driving...???"
According to Rave .... The actuator(solenoid) is required to hold the locking bolt in the unlocked position in the event of power loss during operation.
So basically the only thing stopping the steering lock coming on while driving is the little solenoid pin (P57-14 in my L322 2002 Workshop Manual) which is, of course, very comforting
. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #353102 19th Oct 2015 2:59pm
Page 2 of 3 <123>
