![]() | Home > In Car Electronics (L322) > What's in my boot? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Well for a starter the patch panel with the 2 blue rca plugs is not a standard fit, might once have had a PlayStation or some sort of console fitted.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
The unit on the far left that's silver and more stood on its end is the TCM or telephone control module. The little unit on top of the sat nav which has the cable with the purple end going to it is the Bluetooth antenna for the phone...... 2011 Range Rover Vogue SE 4.4 TDV8
TCM is Traffic Channel Management not telephone , there is a lot of stuff in there I don't recognise . What year and model is it?
The TCM is what bmw used before the ulf module. Land Rover were sold before the ulf came out, that's why you can retro fit a ulf to pair with your mobile from a later bmw, but the 50 pin cable has to be rewired. 2011 Range Rover Vogue SE 4.4 TDV8
RSW Member Since: 13 Oct 2015 Location: Devon Posts: 44 ![]() ![]() |
It's 2002 L322 with RSE from new so the invoice says. Got a phone in the cubby but no Bluetooth. Can't get any TV so assume it's still analogue tuner. But still to many boxs |
The only extra boxes I can see are the DVDs player, up high under the sat nav, and the patch panel with the Rca female sockets on it.
What is the box in front of the TV tuner then as I thought if I got the digital box then it would fit here?
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 ![]() ![]() ![]() |
the two boxes with the RCA connectors id say are video switches for each of the RSE screens, the cable plugged in is probably from the AV out from the TV tuner or dvd changer. leaving you the ability to connect 3 more sources to each screen |
The BM54 radio module is in front of the TV unit. The one that's lower down. It actually contains the amps as well. The dsp is only a sound processor, not an amp, but it seems to be referred to as a dsp amp, so can be a bit confusing.
Thought it was one box will look again when I get chance |
So do you think it's not original RSE? |
Prob need to see a picture of the screen in the headrest to comment on that....
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
IIRC early factory RSE waasnt in the headrests but lower down in the seat back. |
