![]() | Home > General > Potential new owner checking in |
With 180k on it things like the air compressor, suspension struts and just normal bushes will be needing doing at some point in the next few years.
Zigzagsky Member Since: 18 Oct 2015 Location: Sandhurst Posts: 39 ![]() ![]() ![]() |
Thanks for the advice, sounds like it may be worth taking a second look at the car (checking the areas you have indicated carefully).
a search an gaybay for range rover digital should bring said company up.
Interesting to hear.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
Ziggy, I am just approaching 180k on mine (4.4 Petrol BMW V |
Thanks, that's quite reassuring. Given that, I think I've almost decided on getting the car subject to a final look over tomorrow in daylight.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
You see ... you never really needed the word "Potential" in the thread title - once you are hooked - you are hooked.
Hmmm... valid point |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 109 ![]() ![]() ![]() |
There is no escape . . . .then again why would you want to. What doesn't kill you is just bidding it's time. |
Well I went and had another really good look over her and spent a good hour and a half including using a borrowed code reader to check for any error codes. There were a couple of old ones which we cleared and then checked again after the test drive and they didn't recur.
Sounds like a good one |
Picked her up yesterday and very happy.
Good lad!
Thanks, I'll take a look at it.
