![]() | Home > Technical (L322) > Rear diff locked up 3.6TDV8? Problem.... |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613
Good to know that. Still locked up when I left it but didn't go more than a few hundred yards slowly. Will try it more when I get it back.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
I'm obviously a bit more devil may care, when mine did it I just booted it with a wheel locked up and stood on the brakes a few times till it sorted itself out.... just tell it who's boss.... |
Well slight update - after jumping in with one of the other more inexperienced guys as an instructor come guide he was leaving early so stayed the night at my parents. I then went and borrowed a trailer from a friend and returned to the pub to pick up the RR.
Small taster - hopefully you guys can see it but one of the guys posted it on his Facebook page.
Bet that took some paint of your towbar... certainly took some off my old bumper...!!!
Ironically (despite the sound) nothing touched on the bomb hole. Did hit the armature on Soar y Mynydd where they've been patching up the track though. Nothing bad at all, just a bit of dust. Ed |
Right some more (lack of) progress:
Whats VDS ???
Sorry VDM - Vehicle Dynamic Module.
Does it still jerk when driving ??
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2776
For MY07-MY12 the suspension will always lower for any brake system fault, with the logic being to make the vehicle safer whilst there's a brake system fault. Hence the suspension fault can be ignored. |
Where is the TCCM mounted in these vehicles? The D3/D4's TCCM is mounted in the engine bay, is not sealed and fails if it gets wet. Its also a node in the canbus network so when it fails it effectively isolates the halves of the network making ecus on either side of it unable to communicate thereby causing a raft of faults.
Yes the drive does still yerk - took it for a spin in the field last night and got it up to about 30mph before running out of space and did that for a while and that didn't sort anything out.
| All times are GMT |
