Home > In Car Electronics (L322) > fitting ULF...
MattChaloner
England 2016 Range Rover Vogue TDV6 Loire Blue
fitting ULF...
Hi all,
just got hold of a gen10 ULF as well as a new plug from VW in order to do the repin. Followed the guide often passed around which I believe was created by a guy called Ajay. Moved the wires over to their new location on the new plug as instructed, but when I plug the ULF in and turn the car on nothing happens? Got no "telephone" option displayed on the car. Is there something I need to do in order to activate or code the telephone module? Is it a navcoder job perhaps? or should it be plug and play?? I don't currently have an antenna as its in the post, but I didn't think this was needed in order to get the Telephone option to display, I'd just be unable to connect a phone?
I did find another table giving repinning instructions although the 2 tables don't seem to match so I'm a bit confused as to which guide I should've followed?
Hope someone can help me - I've unplugged the ULF for now in fear of frying it although I'm worried it may be too late Sad
Post #353163 19th Oct 2015 6:52pm
MattChaloner
Quick update after a bit more fiddling - remembered that whilst I was repinning I touched 2 wires together by accident and got a brief spark, so checked fuse 22 and it was blown. Replaced it and tried again, telephone has now appeared!
So my next question - does anyone know whether I'm able to pair my phone without the antenna module if I hold it really close to the ULF, or do I need to be a bit patient and wait for my antenna to come??
Post #353176 19th Oct 2015 8:11pm
mjdronfield
You only need power, Earth and I believe the ibus connection for it to appear on the screen as telephone.
Until you get that, you can't do anything.
If I remember right, this is what I used - is the fuse good ?
You can swap 19 and 21 around, that was the only difference I saw on a couple of charts. It still works, as it's only the shields for the microphone. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #353178 19th Oct 2015 8:18pm
mjdronfield
Ah right.... Just seen your update.....
You can always try pairing ? Take it the antenna cable is there already ? It was on mine.....
You may need navcoder to enable voice control though, if you want that facility. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #353180 19th Oct 2015 8:23pm
MattChaloner
That's the guide I went with in the end as it seemed the most popular and I noticed yourself and Ajay had given it to a fair few others! I've got the antenna cable yes, will give it a try, do you know whether the full version of nav coder is needed to change the ULF settings and enable pairing mode? I've only got a trial version at the moment
Post #353196 19th Oct 2015 9:15pm
mjdronfield
You will need the full version of navcoder to write to the units, so yes, just to enable voice recognition.
You don't need it to put the ulf into pairing mode, but you can if you've got it.
I mocked up a pairing button in the boot......
I did a thread somewhere....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #353200 19th Oct 2015 9:24pm
mjdronfield
There is a bit of info here about pairing. Touch pin 32 to 36 to simulate the button press. 36 needs to be connected to the ulf and earth still though.....
http://www.fullfatrr.com/forum/topic14122-60.html
I bought a button from maplin and wired it in. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #353204 19th Oct 2015 9:32pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
I sort of regret choosing Ajay as part of my user name. Should have either just used AJ or Andy Embarassed
Glad to see my pinning chart is still proving useful though Thumbs Up
Andy. Whistle 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #353206 19th Oct 2015 9:39pm
MattChaloner
Will fit a pairing button at some point down the line but having not long had my current phone I bought navcoder for now and used that (been meaning to get it for a while anyway) so I can now confirm that the phone is able to connect with no antenna, just the aerial cable. Struggling to get voice recognition to work at the moment - the lady on the other end keeps saying "sorry?" in a patronising tone. Reminds me of SWMBO.
I tried a test call and apparently I was coming through pretty clearly on the other persons phone but I could hardly hear the other person speaking! I'm hoping this is down to the lack of antenna but time will tell.
I ordered a nut to fix the antenna in place when it comes, I misread the eBay listing though and ended up with just the 1 instead of the 2 required (or 10 I expected to receive!!!)
Does anybody happen to know what kind of screws/bolts/captive nuts/any other fixings I'll need to get the ULF fixed in properly??
Cheers
Matt
Post #353362 20th Oct 2015 10:08pm
mjdronfield
The ulf was never fitted to our cars, so I ended up drilling a bolt hole in the black steel work to mount it near the dsp.
I put rubber washers on the side of it too to make sure it didn't vibrate.
You'll have to try in a few places till you are happy. Not got a million options due to the length of the loom to the connector.
To try the voice recognition, I tend to change the screen display and the shout "map" to get the sat nav map back on the display. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #353365 20th Oct 2015 10:20pm
MattChaloner
Thanks, I'll try the map suggestion on the VR, although I've got a bit of "man flu" at the moment so probably not speaking very clearly.
I was under the impression that the mounting bracket was already there to the left of the DSP as the ULF was intended but never put into production after Ford bought out LR before BMW finished adapting the ULF for the Range Rover. Nevertheless drilling holes and then just getting whatever bolts match my holes is probably a good idea
Post #353367 20th Oct 2015 10:23pm
mjdronfield
If I remember right, I used an existing hole for one point in the ulf, but the other hole in the ulf didn't line up with anything. They were both at the top, so easily accessible. They held it tight and in place so I didn't do anything at the bottom of it as it's hard to access being in the depths of the boot.
I pushed a rubber washer in from the side to stop any vibration from the bottom...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #353504 21st Oct 2015 6:03pm
