![]() | Home > In Car Electronics (L405) > Digital dashboard brightness / Interior lighting |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8808 ![]() ![]() ![]() |
Can't help I'm afraid, have you tried beating it with a tree branch...... |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6830 ![]() ![]() ![]() |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
On the dash question, no idea. If you look in settings on the infotainment, there are some settings for the Nav at night. Maybe fiddle with those? Might have a knock on effect on the dash.
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Afraid that the branch only works on Austin 1100s |
Sorry, should have added that the mood lighting is on |
So the switches should be illuminated and there is an amber LED to indicate that the car is locked.
Well done Emperor, I'm going to go and check again but what you've shown is pretty clear cut. Even I can see that! |
Just gone out and checked and it's in darkness. Think the bulb has gone out. Thanks very much for your help |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
For the dash brightness, have you got it on 'torch' view or normal? Torch is the option that highlights the speed 5-10mph either side of your current speed and follows it round the dial, whereas normal view illuminates the whole speedo & tacho and is quite a lot brighter. Steve
It's defo on torch view, l didn't realise I could change that but I'll try and find how to and see if that's any better. Thank you, it's very much appreciated |
The car is going in next week to have the illumination in the memory seat modules ( both sides ) done but if any one out there can answer me the following I'd appreciate it.
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
I think you need to get your car changed to a new one |
It's only two years old (I've had it for ten months) but like you I don't do a lot of mileage, so didn't notice until the dark days arrived recently |
I got a 16 year old pubescent son who explains me everything |
