Home > Maintenance & Mods (L322) > no hot air middle vents
tevista
Scotland 2003 Range Rover HSE Td6 Zermatt Silver
get hot air from windscreen vents and floor ones but the middle off dash blow cold - anybody any ideas ( appart from dont select them ;--) ) ??
Post #353052 19th Oct 2015 11:39am
have you turned the dial to red... ... - .- -.
Post #353054 19th Oct 2015 11:41am
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
Have you turned the dial in between the vents to 'red' as 'blue' is obviously cold air and red hot.
Post #353055 19th Oct 2015 11:42am
tevista
yeh , hot top and bottom but cold from centre .
Post #353056 19th Oct 2015 11:47am
could be the blend motor flaps sticking....do they work when in auto mode.. ... - .- -.
Post #353058 19th Oct 2015 11:58am
tevista
good point , try that at 5 when i head home .
Post #353063 19th Oct 2015 12:11pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
I have same problem. No warm air comes out, only way to get warm air out is to press the direction button below to manual send air through the middle vents. Won't send warm air out at all on auto. It will send out cold air when the dial above is showing blue but no warm air on red.
Post #353221 19th Oct 2015 10:33pm
tevista
Yep Lad , same fix as yours . Another gremlin creeps in .
Post #353230 20th Oct 2015 6:41am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Wonder if this is a seasonal thing I have just had the same problem.
Using the manual override as above gets the air blowing through the centre and outer vents again then adjust hot/cold in usual way must be sticking with being on cool all summer. Another quirk? Mine was a blue one! Smile
Post #353273 20th Oct 2015 10:46am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
People - these are not gremlins or quirks.
These are features. Thank you.
. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #353275 20th Oct 2015 10:49am
