![]() | Home > Maintenance & Mods (L322) > Suspension different heights on each side.. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
should be within a few mm's ...make sure its on absolutely level ground and toggle between all height modes and then measure with the engine running, joe90's height chart [below] might help,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8792 ![]() ![]() ![]() |
The EAS has a + or - 9mm tolerance, so they could be up to 18mm different side to side,
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Been out for a drive and took the readings as soon as I got home incase one corner was going down slightly. Now I'm running 255/55/20 tyres so obviously the 55 profile will make a difference. The measurements were as follows..
yes it can but you have be very careful.. ... - .- -.
Is it fairly straightforward to do with an iid tool? Need to order myself one still. |
Robgosty Member Since: 20 Dec 2013 Location: Manchester Posts: 232 ![]() ![]() ![]() |
If you are measuring from the centre of hub or bottom of rim how will tyre profile make a difference ? |
Because the thicker profile tyre will be slightly higher off the ground won't it |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
@JPS - yes but the tyre makes no difference to the calcs.
Ok sorry my bad |
@JPS ... No problem, IID tool and RSW Allcomms can adjust the heights independently - make sure your car air suspension is in good condition before you start - ie no leaks.
Thanks I shall get myself an iid tool ordered as want one to update my Bluetooth module also. |
It is no problem calibrating the system, just take your time and work through it, the instructions from Gap are excellent.
