![]() | Home > Maintenance & Mods (L322) > Possible to make the dash/cluster lights come on startup ? |
For my MY02, is it possible to make the dashboard (binnacle) lights come on when I start the engine, so to switch them on with ignition live power, instead of with the sidelight switch? Very often difficult to see the dials and info even on what appears to be quite a bright day. .
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
thats an interesting one Tim..
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8792 ![]() ![]() ![]() |
Looks easy enough, Slate (grey) and red wire in position 8 in plug C0230 that feeds from the LCM, cut it and join to an ign live and it should work... may have a go later as I'd like it as well....
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
I'm wondering if they come on if you activate the DRL function with an IID. |
Don't think so, that wire splits from one leaving the LCM that switches all the interior lights on that come on with the outside lights... heater controls, mood lighting etc.... Pete
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Or just drive around with your sidelights on all the time and people will think your a Volvo driver |
That would be OK, how to make that happen when I start the car? .
put a bit of tape over the sensor to make it think its dark... ... - .- -.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1525 ![]() ![]() |
Iirc, All the interior lights run through a power transistor in the the lcm, and their brightness is controlled by the variable resistor sitting next to the light switch.
No auto lights on a MY02 |
That's what I thought I posted above, probably didn't make it clear enough.......
Wondering if I could feed from my DRL unit ( I have a separate DRL setup for fog lights, not IID controlled) .
Any ign switched live would do , the lights will draw next to no current, they will come on at full brightness but lets face it they need to be!!!
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
@Joe90. Not long replaced the read out binnacle bulbs on mine with led's. As mine is 04/05 specmight be different to yours.
