Home > Technical (L322) > Left it unlocked last night... |
Lookers Park Royal Member Since: 30 Apr 2008 Location: London Posts: 463 |
HEVAC fan fault is the likely culprit! |
5th Nov 2010 10:19pm |
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 |
Almost elpeede Your right about unlocking it and all systems boot up but in my 05, if you only open the door when it has NOT been locked it only wakes up "slightly" and will go to sleep again after 2 or 3 mins. In my experience, unlocking the car but not immediately driving it keeps it awake for god knows how long and ultimately draining your batt. @ Duke Thrust - here is an example: Get home from work and lock it up. Oh , left my briefcase in the car . Unlock it and all systems (including Nav Screen) power up. Grab my briefcase and then put my key in the ignition, turn it to 2nd position back again and key out. This shuts it down again. Takes 2 seconds. If I don't do this, Nav screen stays on even after I have re-locked it. Now, on the flip side, if I haven't locked it and need to go back to the car to get something, I do not have to go through this routine. This is my experience and I don't worry about my battery anymore. mike. |
6th Nov 2010 1:44am |
Duke Thrust Member Since: 07 Jun 2010 Location: Gloucestershire Posts: 57 |
Locked it last night, will see what it's like this morning...
6th Nov 2010 11:58am |
td6 vogue Member Since: 31 Dec 2009 Location: essex Posts: 93 |
Seems i have the same problem. New battery a couple of weeks ago now car is completely dead. I always leave it in the garage unlocked. |
7th Nov 2010 7:43pm |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
I once noticed that the nav screen was on in my car long after I'd locked it (prob 30 min or so). I opened and relocked it and it went off. Not sure how this helps but I think sometimes the car doesn't sleep. |
7th Nov 2010 9:09pm |
Okay, so locked each night, no problems since - will update in case of further problems. |
9th Nov 2010 11:03am |
