Home > Maintenance & Mods (L322) > Heater cold but engine normal
Fil1138
Hi all, my first time on here a just brought my first Range Rover td6 main problem is engine runs normal temp around 12 o'clock but heater only blows cold, change over valve is cold and so are all pipes in and out, coolent valves are hot to touch but all pipes in and out are cold too so don't know where they are getting there heat from, I have changed auxiliary coolent pump as that didn't work but still no heat from heater, have also bled system trice and still no heat, please help as weather getting colder and so am I
Post #353551 21st Oct 2015 11:30pm
Could be an air lock or blockage in the heater, try removing one of the heater pipes and sticking a hose up it to see if water will pass through the heater...
Also worth getting the codes read, that may point you in the right direction...
Does the fuel burning heater work??? Pete
2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior-Click here for Thread-
Post #353559 22nd Oct 2015 12:17am
Fil1138
From what I can tell the fbh doesn't do anything, either with the remote fob or by setting the times on the radio for it
Post #353565 22nd Oct 2015 7:44am
Needs a good look at with a diagnostic device then...
If you are going to keep it I'd recommend an IID tool, does more than the dealer can and will pay for itself very quickly...
https://www.gap-diagnostic.com/
They are a site sponsor, as is Dan at Duckworths who can sell you one from this country, some have had to pay extra tax when getting them direct...
http://www.fullfatrr.com/forum/duckworth-parts-vf24.html
Still worth a go with the hose though....
Thumbs Up Pete
Post #353587 22nd Oct 2015 10:34am
CS
I've no experience of the TD6, but on my petrol 4.4s the final stage resistor in the heater system failed resulting in no heat into the cabin. I believe that is a common problem. Could that be relevant to the TD6 too? Only Range Rovers since 1988
Post #353673 22nd Oct 2015 7:15pm
^^^^ very relevant - usually affects the fans but could impact on heat too. Worth a check/change out. .
Post #353728 22nd Oct 2015 11:02pm
I can't see how the FSR called an Output Stage (voltage amplifier) in Rave can make the OP's water pipes cold, it just controls the fans not the water valves...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Pete
Post #353738 23rd Oct 2015 1:36am
Fil1138
I have had another go with it and found that the crossover valve has no power going to it thus to open it, is this what is supposed to happen or where does it get its power from ?
Post #354371 27th Oct 2015 6:25pm
As I said above, you should get the codes read, there will be something to point you in the right direction, guessing why there is no power to it doesn't really work.... it could be a direct feed or it could be can-bus controlled, the signal probably comes from the HEVAC ECU... could be that, or the FBH or something else.... I take it you have checked all the fuses...??? Pete
Post #354376 27th Oct 2015 6:59pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
Crossover valve is only powered when FBH is on
Nige
Post #354378 27th Oct 2015 7:17pm
Fil1138
As iron horse posted, the crossover valve IS powered by the FBH so I looked there and found the fbh had been unplugged from its power supply, I plugged it back in and power was restored at the crossover valve, but firstly the fbh ran but would not stop until I unplugged it from the power, and secondly it didn't seam to get hot or warm water, as heater vents only blew cold but could turn blower off and on with fob remote, any ideas why it won't stop running even when the car is locked, did leave it running for about half hour until I unplugged it ?
Post #354540 28th Oct 2015 10:03pm
ironhorse
if you interupt the FBH running cycle sometimes it can carry on running when powered back up (carrying on from where it left off)
that plug has been left off for a reason ,start from scratch dont take any short cuts to diagnose it and KEEP YOUR BATTERY FULLY CHARGED OR YOU WILL GET FALSE TEST RESULTS
best thing is to remove the fuse (cant remember the number off hand) connect everythig back up and leave it for a couple of hours,
replace the fuse and then see what happens
if it runs again when you replace the fuse leave it for about 40 mins to do its own thing (should cut out after 30ish mins)
might need faults clearing with diagnostic tool to stop it sulking
FBH is a very simple bit of kit but connect it to a landrover product it can be a nightmare
read and read again till you know how these things work or you will be chasing your tail forever
http://www.the75andztclub.co.uk/forum/showthread.php?t=71982
http://www.the75andztclub.co.uk/forum/showthread.php?t=100297
Post #354684 30th Oct 2015 9:45am
