![]() | Home > Technical (L322) > Howl under medium acceleration - 4.2 SC |
Dan, have you checked for air leaks? Smoke tested it? Easy DIY job with a disco smoke machine! |
Thanks for your replies guys!
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
Dan, my advice would be to remove the pollen air filter assembly and take the car for a drive as this will give you a clearer indication of the noise - I drove mine with that removed and what a difference in noise from the Supercharger !! You will need to remove the engine cover to take the pollen filter assembly out (quite easy)
kyle h. Member Since: 15 Feb 2016 Location: West Virginia Posts: 23 ![]() ![]() ![]() |
Hi Dan, I believe I have a similar noise as you. I had read somewhere that there are numerous LR tech bulletins with various noises. Have you had a look through any of those?
Hi Kyle,
When driving today the noise was really noticeable, frustratingly you cant hear it at all on the dashcam:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
just a thought Dan, why not spray wd40/water/something on each of the pulleys and see if the noise goes away when you rev. ... - .- -.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
+1 same here air con |
Sorry should have updated, all new belts, pulleys and idlers a couple of weeks ago. |
Did that fix it?
bluebattery Member Since: 04 Apr 2016 Location: London Posts: 21 ![]() ![]() ![]() |
Hi Dan,
Sam,
