![]() | Home > Technical (L322) > Power Reduction Mode... |
MartSim73 Member Since: 12 Oct 2015 Location: Wimborne, Dorset Posts: 53 ![]() ![]() ![]() |
...well, plenty of onlookers I see but no response. Guess that's just being a newbee here?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
On the plus side that is a nice looking FFRR. |
Who did you buy from (private or otherwise)? |
Thanks northernmonkeyjones and pld118,
If it's from a dealer you have some rights, as well as any warranty they have to give as a matter of course, so he should be pretty much sorting it for you full stop. And reputable dealer worth his salt would not want the bad press and get it back on the road for you asap. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
You could ideally do with finding someone who can read the fault codes off the car
Well it seems the first issue is confirmed to be a full and blocked DPF filter which if they can't unblock will require a replacement.
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
Mine did the same thing yesterday. I was just by a petrol station so pulled in to stop for about ten minutes, it was then ok again. I've done about 200 miles since and everything seems fine - do you think I still need it checking?
I think you are getting a tad confused with problems relating to the 3.6 & the 4.4TDV8’s sir... Changing to silicone hoses relates to the 3.6! And the sticking EGR issues also refers to the 3.6! I only mean for this to inform future readers factually sir ![]() The large amount of fault codes don’t necessarily mean big problems sir, mearly point to battery voltage issues during the starting cycles. Now, to your troubles! I would like to suggest your FIRST job must really be changing the battery! Yours will now be 4yrs old and sounds like its failing and FF’s REALLY DONT like failing batteries sir! Secondly, the DPF will cost a couple of thousand if it needs replacing ![]() Yours does not sound like a straight forward group of “usual issues” so move forward with caution would be my advice sir... Good luck ![]() |
@MartSim, Craig offers sound advice when advocating that you make sure anyone doing repair or remedial work knows the Range Rover well, has the ability and appetite to properly repair things and doesn't cut corners. Otherwise, an expensive initial purchase could become an even more expensive and long term headache. If you are satisfied the dealer will properly make good, then great. Regardless, I would make sure that's all in writing, if not already. If you have doubts, you could request a refund. This is English law and is based upon personal experience so hopefully will assist you if things complicate ![]() Sale of Goods Act 1979: It is helpful to be aware of Sections 14 and 48 of the Sale of Goods Act 1979. The act relates to the fact the consumer has a right to expect quality, fitness for all the purposes supplied, freedom from minor defects and a reasonable expectation for repairs to have been undertaken within a reasonable time without causing significant inconvenience. If these things are not the case with your purchase you can assert non conformity to the contract of sale within the period of six months from the date of purchase. References to ‘caveat emptor’, meaning ‘let the buyer beware’: If you buy a car from a *private seller* 'let the buyer beware'. You have fewer legal rights, so make sure you inspect the car and know what you are buying. You will only be able to claim against the previous owner if he/she lied, for example about its age or mileage. You will not be able to claim where there are faults with the car. However, buying from a motor trader (or dealer) is a different matter and you have greater rights - 'Wear and tear': A seller is not responsible for fair wear and tear, so you cannot claim goods are unsatisfactory just because they've become a bit worn over time. For goods to be unsatisfactory they need to be faulty when you bought them, even if you didn't discover the fault until later. If the goods don't last as long as they should, this suggests that they were faulty from the beginning. ** If a defect is detected within 6 months, it is presumed that the defect existed at the time of sale or delivery, unless the seller can prove otherwise. ** Whilst better to do so, *** you do not have to examine items before buying them. This means that if you haven't spotted something wrong before buying an item, you can still claim it is not of satisfactory quality. This applies even if you would have spotted the defect if you had examined it closely ***. However, if you don't complain quickly, you may have to accept a repair, replacement or partial refund, rather than a full refund. More information on the S of G.A can be found on this link: http://www.legislation.gov.uk/ This UK Citizens Advice Bureau link is also another helpful source of information on UK Consumer Law: http://www.adviceguide.org.uk/england/cons...ucts_e.htm |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 ![]() ![]() ![]() |
Martsim73 - I have just owned my 2011 TDV8 4.4 for the same time as you, and just had the same problem as you on the first long journey in the car. However, it seems to have cleared itself now, and no warning lights on the dash. I aim to buy the IID code reader, and see if any old codes exist.
Stuart,
The law has just changed... BUT....the Consumer Rights Act came into force on 1 Oct 2015. The SOGA 1979 still applies to goods bought BEFORE 1 October 2015 and the OP makes clear that the purchase of the RR occured before 1 October. This link should hopefully simplify things for those with issues regarding goods and services supplied both before and after 1 Octobr 2015 (Legislation Gov UK hasn't been fully updated at the time of writing and it can be a heavy read): http://www.moneysavingexpert.com/shopping/...s-exchange ![]() |
Hi all,
