![]() | Home > Technical (L322) > Coolant Leak near Alternator (V8) SOLVED |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8817 ![]() ![]() ![]() |
Yep, it sits in the water, it's a totally sealed unit obviously... try nipping up the bolts holding it in, if not sounds like a new seal...
Hi Pete, thanks for the speedy advice as always.
I'd get it done now if I were you, pretty easy job, worst bit is getting the fan off, I've got a home made tool for it.
@Haylands - thanks for the offer on the fan spanner - presently running without the fan anyway - easier to leave it off over winter and speeds up access when I have repairs to do - should that need ever arise with the FFRR
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 ![]() ![]() ![]() |
You say you running your car without the viscofan SMUTT, how does that effect your cooling temperature? Is it safe to drive without the fan over the winter?
Its safe to do so but! A, you need to make 100% sure your AC fan is working and you drive with your AC on, as this now becomes your emergency cooling if stuck in a traffic jam! & B, if the AC fan gives up the ghost... You have NO redundancy sir |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
when tightening the bolts, just be carefull not to touch the red battery cable with the socket, or spanner, it will spark big time! do not overtighten, if you strip a tread on that housing, its a massive job to replace the front timing cover. if you take alternator out, use a bit of paint to mark one bolt hole to the corresponding bolt hole, as its easy to put it back in on 'out of position'
^Now there is a man with experience^... |
@Cam-Tech-Craig - thank you for the warning |
Yep, they quote 10lbft for the alternator bolts, that's not very tight at all so don't go mad....
@Haylands - 10lbft - that is light - thanks for pointing that out to me.
Yes you can mine was a Bosch refurbished one, got it just before last xmas... Pete
