![]() | Home > Technical (L322) > "Offroad View" |
iconoclast Member Since: 20 Oct 2015 Location: In, Out & Around... Posts: 35 ![]() |
What is Offroad view? (found in the appearance portion of the settings menu in the cluster)
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8777 ![]() ![]() ![]() |
As above,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8817 ![]() ![]() ![]() |
Blimey, how the other half live.... |
Can see that function getting used lots on mine |
thank you all for the help. if i understand correctly the "offroad" feature has to be enabled in the speedometer/cluster and then it will only show that screen once i enable or engage mud setting... correct? https://instagram.com/_.iconoclast/ |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1426 ![]() ![]() ![]() |
On my 2012 WM the dials screen shows off road info as described above whenever a terrain response setting other than standard drive is selected. It also shows if you have low ratio. HDC etc on. That happens automatically.
Are you able to customise the later LCD dashboards at all.... The picture above shows the speedo on the right, that would really bug me as mine is on the left now...!!! Pete
Not as a standard thing Pete, I'm sure some clever so and so will come up with a way to customise the display Though. There is nothing that can't be fixed with a hammer😜😜
Oh well, and there was me going to shell out £40,000 on a nice 5.0 S/C... I'm not having one now the speedo is on the wrong side... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3668 ![]() ![]() |
You could turn the screen upside down |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3956 ![]() ![]() ![]() |
You get used to speedo on the right, I have a question, in the middle of the Rev counter there is a box that in the pic above shows "D" -- in the middle of the speedo there is another box but it never shows anything was it ever intended to, if not why have it ? Geoff |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Geoff it can be programmed to display the digital speed. See my post below and scroll down further for a video I uploaded |
Can it be done with the IIDTool?
I'm pretty certain that any CCF editing the Faultmate can do the IID tool can too |
