![]() | Home > Wheels & Tyres > Anyone tried diy manual fitting tyres ? |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
Ive done big motorbike tyres with 2 tyre levers and 2 blocks of wood. the hard part is breaking the bead , its much easier to use 2 sash clamps , the type that joiners use, BQ sell them.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
You'll still need to take them somewhere for balancing
I used to fit Mini tyres regularly when I was younger, they were easy enough but I think you will find it almost impossible on bigger tyres. Even if you fit them yourself you will still need to get them balanced. |
I've done it a few times using a length of timber and a brick to break the seal but only on steel rims. You really need to use a machine to fit tubeless tyres otherwise you risk damaging the seals when fitting. Not worth the hassle IMO |
When I am having tyres fitted I go to great lengths to inform the fitter that my wheels are unmarked and wish them to stay that way and any damage they do will be charged to them. I also stand over them whilst they do the work just to make sure they don't make a hash of it.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3310 ![]() ![]() ![]() |
A tyre changer and wheel balancer are two of the best things we ever bought for the workshop |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
In terms of doing it myself, I was planning on one of those manual tyre changers and not bodge it drive over the wheel to break the bead stuff.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
I've got one of the manual tyre changer / bead breakers that are advertised on ebay (mine was about £50) . Its bolted to a pallet and its used for changing tyres / fixing punctures on the quad bikes, Polaris Ranger and various trailers on the farm. I wouldn't consider using it on a car tyre with alloys though, but have done a tyre on our Ifor Williams horse trailer.
What makes you not want to try an alloy ? Is it the type of bar that you use or something else ? I've read about using the bar with the nylon rollers for alloys. V8 or else ... |
Well the effort I have to put into getting the trailer wheels off and then back on again I'm fairly sure I would end up damaging the alloy with just the basic set up I have. I could get better kit but it works fine on the steel wheels the trailers have. With the cost of the alloys and new Pirelli tyres I don't see the point in economising on the car wheels.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
If you shop around you can sometimes get them fitted and balance for £10 a wheel for a set. But yes, £15 a wheel is normal. What annoyed me, is that the backstreet guys tend to sort of rush the job. Especially when they forget you have alloys, as the spotty corsa driver kid, take the nuts off, and let them drop on the rim edge. And then try to break the bead, with it still half full of air, and it then whooshes and buckles the tread portion. 'Slow down, this isn't a Grand Prix!' And the place is so dirty you have to really be careful what you lean against! I got into my car, drove home and was walking down the drive and a neighbour pointed out I had a new tyre info sticker up my back!
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Second hand tyre machines aren't that expensive if you have somewhere to put one, i'd have one if i had the space. The manual ones probably aren't bad, there are special bars for alloys, potentially it's hard work. The bigger the tyre the easier they are to fit normally.
