![]() | Home > Wheels & Tyres > Hardest alloys to clean? |
Never used a brush as no matter how soft they are they still leave tiny marks on the lacquer.
Dooka wheel Mitt made from lambswool |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
If you are going to use the C5 then you'll need the larger bottle for 4 20" wheels.
Thanks all.
The reason the cost is so high is normally down to how much paint correction and polishing is required.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672 ![]() ![]() ![]() |
+1 on the demon wheels spray. very good results and not so abrasive as that Hot Wheels acid which should banned!!. Halfrauds often do 3 for 2 and thats the chance also to get demon tyres for the opinion dividing wet look and some AG alloy seal which does an excellent job particularly on the inner wheel area. The time to remove, clean and seal 4 wheels with the AG seal is well worth it as for a few months after, brake dust washes off very easy.
I was told it will last between 1 & 2 yrs Ryan... BUT! i believe TFR will strip it much quicker so NO hand car washes with our eastern european friends!!! |
