Home > Off Topic > One for the AudioPhiles or AV buffs
Is there any speaker out there that is about 1" tall and utpo 10" long that would be perfectly suited to being a centre speaker?
The reason i ask is my TV has been replaced and the new one sits much lower so the Onkyo 7.1 setup i currently have has a nice 3" tall centre which wont sit infront of the TV without blocking the IR sensor.
Now its not too bad as i do most stuff through my Am Stick or Sky+HD(waiting for the Q box to show up if ever!) and can use wifi via the remotecontrol app to turn it on or off when my harmony doesn't get its signal through for ON/OFF and it would look much nice if i could get a centre to sit under the screen.
I've looked at soundbars and the ilk but they are still too tall even for long ones and with the Bravia having a thin wire frame for a stand 1" tall by 10" long should sit perfectly in there.
Failing this ill have to work on a way to raise the TV on the unit without it looking out of place which is going to take a lot of time to Fab and make nice... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354244 26th Oct 2015 5:14pm
I can't think of any speaker that small - you'd need an array of 1" speakers
I'd block the IR sensor & use something like this - i've used them for kit that's sitting in a cupboard Thumbs Up
Post #354252 26th Oct 2015 6:47pm
Thing is if I block it with something taller then it would need to be quite shallow to fit in the gap between the stand and the display so back to square one due to space.
It's this setup
http://www.google.co.uk/shopping/product/3...gJ#sgro=om
You can see the light bulge I need to deal with more easily here
http://www.sony.co.uk/electronics/televisions/w800b-series FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354255 26th Oct 2015 7:23pm
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I don't know if this would help but here goes.
I have a Canton DM50 soundbase that the television actually sits on. It's only 65 mm high but 545 mm wide and 330mm deep so provides a very solid base for the telly to sit on.
http://www.richersounds.com/product/soundb...t-dm50-blk
Post #354266 26th Oct 2015 9:01pm
It sounds(!) like it has its own built in psu and amp Sad
No mention of if you can disable the sub and built in amp... Might give them a buzz tomorrow about it 👍 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354282 27th Oct 2015 12:30am
miggit
Can't the TV be lifted up? it might be worth trying to do, especially if you have a good centre speaker at the moment, as I fear that you maybe a bit Sad with the sound performance of a 1" high speaker. For starters it will be a very tinny sound, as there is no way it will move any air.
Am I correct in thinking that you've got it all on a stand? Or have you gone and got one of those 6 foot high jobbies and run out of ceiling height Shocked
If it were to be lifted higher you'd have to drill new lower holes in the mount and extend the top by the same, 10 minutes with a Meccano set could save a lot of disappointment Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #354290 27th Oct 2015 1:07am
The centre speaker is purely speech but has two decent sized drivers in it Smile
Problem is that it's a long solid oak unit that it sits on so finding a stand to increase its height is neigh on impossible unless I can find a nice oak that's being felled that I could go take a chunk of and get my dad to shape it for me.
The frame/stand that's currently fitted to the unit offers no real way to change its height other than wall mounting it which I don't want to do as I like having a few inches of space behind it to aid dusting and hoovering of my tv units 👍😄 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354292 27th Oct 2015 1:21am
FYI the system I have is the slightly older version of this with 2 additional side speakers 👍
http://www.uk.onkyo.com/en/products/sks-ht588-125348.html
The TV is one of these bad boys
http://www.sony.co.uk/electronics/televisions/x8500c-series
And the Amp is the old boy Smile
http://www.sony.co.uk/support/en/product/str-dg820
Which will have to be upgraded at some point to support 4k but i'll worry about that when it comes online with Sky/Virgin FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354293 27th Oct 2015 1:24am
miggit
Shocked You went for the whole package then Shocked I just got the amp and added different speakers to mine, I think my centre speaker is 2 x 5" Eltax, it has bass reflex ports which add to the sound nicely, Kef floor standing speakers front, Eltax 4 way mids and 2 way rears. I did bag some 5 way Eltax for the fronts, but I never quite got round to changing them...... one day, I might try the bi pole rears that I got at the same time!
Have you looked at Bose? they make the best sounding small speakers that I've heard, but there will always be a compromise with the sound the smaller you go.
Are you using the table top stand that came with the TV? can that not be jacked up on a couple of bricks ? Wink And then hidden with a decent centre speaker Thumbs Up
If your using the VESA mount on the TV, it should be possible to move it all up, you'd need some angle iron to extend the top, but it is doable Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #354298 27th Oct 2015 2:05am
miggit
take a front rear pic and then we might come up with a few suggestions Thumbs Up
If your speakers are the same spec as the ones in your link, they are bass reflex, so you'll really notice if the replacement isn't....... just turn all the bass down and the treble up to get an idea, FYI most tweeters are 2" high, so anything smaller is going to sound like that Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #354303 27th Oct 2015 2:28am
I've got some Bose kit, but the VCS10 is still just over 3" high.
Post #354311 27th Oct 2015 9:30am
Speakers are the same spec Smile
Amp isn't an Onkyo however, they are just my speaker package Very Happy
The TV isn't wall mounted but is using the standard stand hence the issue with the centre being too tall.
It would be great if sony offered something that fitted perfectly in the gap and as such contoured to the TV bottom.
Checked Bose out and theirs are still 2-3" tall Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354312 27th Oct 2015 9:33am
Checking Sony.co.uk instead of .com Very Happy I've found these now Smile
http://www.sony.co.uk/electronics/sound-ba...ls_default
http://www.sony.co.uk/electronics/sound-bars/ht-ct80
The soundbar sounds like the best option if it works by allowing me to drop the sub. Not perfectly heighted but should be ok Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354313 27th Oct 2015 9:47am
A sound bar isn't just a speaker though - it's going to have a line level input and a built in amp Whistle
Post #354316 27th Oct 2015 11:31am
one of my problems Sad Unless i buy it, pull the gubbins out and run decent cable to the speakers in some way.
You'd think someone would design a centre speaker like this or is it a missed market?! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354326 27th Oct 2015 12:46pm
