![]() | Home > Maintenance & Mods (L322) > Lower tailgate support bolt detached |
Wow |
0949 Member Since: 01 Nov 2013 Location: Notts Posts: 19 ![]() ![]() |
I'll keep you in the picture-literally... |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
If Landrover can cite UK weather as a reason not to tackle corrosion nothing would surprise me Howard
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
members/owners should check also, that these tailgate bolts are not un-doing themselves, as I found both of mine were a couple of turns out...its the slight rotation effect of the wires being folded, (I believe) that will undo a loose/or perhaps strained bolt. -only for the owner/guest to sit on said tailgate to change his/her boots, and in an instant, -offer his/her bulk to the mud!
@JBA - good tip - will check mine - nothing worse than wasting a good whisky Howard
on the 06MY i drive often i have replaced both units at the rear and by god they were really rusted in place!! Glad the torx screw has gone for a better bolt design! I applied a load of grease to mine and then peeled the rubber back a little and shoved loads in there to to make sure it should push moisture away and they should last at least another 10years now FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Thanks for the comments everyone. Here's the image showing the rust which appears to have allowed the bolt to pull through. Bit underwhelming for a 2012 car dont you think? Will post warranty verdict in due course
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 412 ![]() ![]() ![]() |
i knew that the straps rust but thats really nasty.. ... - .- -.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1418 ![]() ![]() ![]() |
Disappointing indeed. The 2012 vintage does seem poor for corrosion. If it was mine, I would be asking LR/its dealer whether this falls within the 6-year perforation warranty. Only Range Rovers since 1988 |
