Home > Technical (L322) > Old topic air suspension
mudknight
2003 Range Rover Vogue Td6 Java Black
I apologise in advance, old topic I know , my TD6 2003 has suspension inactive on dash , no red light on the ride height adjust knob , checked fuses , in glove box and in boot , can't hear compressor at all . Does this mean compressor replacement or are there other things it could be ?
I've done lock to lock but not worked .
Post #355208 3rd Nov 2015 9:32pm
If there are no lights on you have a hard fault, even if you fix the problem it won't work until reset with a diagnostic tool...
The comp won't run as the system has switched off until reset.
No good guessing, get the codes read or buy an IID tool or similar and do it yourself... Pete
Post #355229 3rd Nov 2015 11:15pm
mudknight
Cheers Pete
Post #355256 4th Nov 2015 5:21am
sounds very much like the problem that they had on the wheeler dealers L322. Get the codes read as Pete says then you will know where to start.
I think it was a pressure static when filling fault that they had on the TV, and was down to the compressor failure..... There is nothing that can't be fixed with a hammer😜😜
Post #355333 4th Nov 2015 6:20pm
