![]() | Home > Technical (L322) > Help with windscreen scuttle panel removal |
It needs to be pulled off, with a puller tool, maybe some judicious use of the two hammer method, with squirts of WD40 (other lubricants are available) as well to help break the seal, last option is heat but don't melt the plastic!
webber Member Since: 26 Nov 2013 Location: Stockport Posts: 29 ![]() ![]() ![]() |
Great, thanks for the quick reply. I thought that was probably the case but wanted to check before I go buy a proper puller to do the job |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16400 ![]() ![]() ![]() |
Wants a shock to dislodge it sir... |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
Strange, we had our windscreen replaced earlier this year by autoglass and they had all the correct tools to remove that part from the taper.
I wasn't sure if I could give it a whack as I didn't want to damage the mechanism but I think I'll give that a go.
Thats a poor company then!
Would a penetrating oil work better than wd40?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8765 ![]() ![]() ![]() |
What, like telling it how much a screen costs.... ![]() ![]() I'm with Craig, that is a fundamental part of changing a screen and will be done on most cars, if they can't get that off you don't want them doing anything else... ![]() __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Be careful the acetone does not destroy the plastic or paintwork. I have recently found PlusGas to be the answer for seized items. Good reviews on Amazon Howard ____________________________________________________ 2002 4.4 V8 LPG Tartarini Have RSW AllComms in Cheshire J17 M6 - happy to help. *Gone: Classic Vogue SE Auto V8 3.9 ![]() |
acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24 ![]() ![]() ![]() |
+1 for Plusgas (and comments about finding a different fitter!) |
Thanks for the advice everyone, I managed to get it off with a £11 puller and some wd40 so not sure how the windscreen company found it so hard.
Its your car sir!
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
A good windscreen company certainly should not be baffled by this, have they never fitted a screen to a RR before |
