Home > In Car Electronics (L322) > Is the Message Centre covered by breakdown insurance.
Clivefog
I've noticed that the Message Centre is missing more pixels that before. I've only owned it a month so it is going bad quickly. The warranty has a get out clause saying it does no cover in cabin electrical items. I will be claiming that it is a major part of the vehicle without which you can not read the milometer. What do you guys think ?
Post #354807 31st Oct 2015 5:13pm
fill in your car profile clive so we know what you have.. ... - .- -.
Post #354809 31st Oct 2015 5:36pm
Don't think you stand a chance mate, but worth a go I suppose..... Pete
Post #354831 31st Oct 2015 9:58pm
/\ as above
Common fault and probably why it's excluded
There are loads of places that repair them for a couple of hundred quid - search Range Rover Pixel or something like that
Post #354833 31st Oct 2015 11:29pm
Clivefog
I've found a while you wait service for £170 with remove and refit. Lot cheaper if I send it off but the FF is my daily driver and I need it for work.
I think I'll get it repaired and send the invoice in. If you don't ask you don't get.
Not having a good day, saw the FFRR on Wheeler Dealers with the new air pump and mine, yep you guessed it, it works but oh so slowly. Repair kit ordered let's see if that resolves it
Post #354836 1st Nov 2015 12:11am
mjdronfield
My warranty covered mine, after I explained that without being able to read it I might miss low oil, engine overheating etc which are pretty serious.
You might get lucky. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #354842 1st Nov 2015 10:12am
Clivefog
I will try as you say it is a major part of the vehicle not just an add on.
As far as the EAS tried it again today and it is loads better, perhaps it had not been used for a while? Repair kit coming may not have to fit it for a while now. I may not even change the height ever but it is good to know that it is working.
Post #354865 1st Nov 2015 3:33pm
Check you can get low box as well, that can stop with lack of use... (and then select it once a month to keep it working)
Piston ring replacement is easy and will help but they are pretty slow anyway on the earlier ones.... Thumbs Up Pete
Post #354927 1st Nov 2015 10:12pm
Just noticed where you are and your lucky as if you have problems you are close to Cam Tech Craig and he knows his stuff.. Thumbs Up Pete
Post #354928 1st Nov 2015 10:18pm
Clivefog
Yes only 15-20 minutes away. I'm coming up to retirement, have done all my home servicing for over 40 years, just getting a little long in the tooth for some jobs now, still grates paying for something that I could do.
Post #354944 1st Nov 2015 11:44pm
Clivefog
Yes the message centre is covered. Just need to find the time to book it in.
Post #355468 5th Nov 2015 3:36pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
^^---- Never expected that - but well done Thumbs Up Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #355484 5th Nov 2015 4:59pm
Result Thumbs Up Thumbs Up Pete
Post #355488 5th Nov 2015 5:06pm
Clivefog
Booked in for 2 weeks time, insurance will pay the electronics direct. What could be the only draw back is the place is in Portsmouth, however I need to go the Isle of Wight - two birds with one stone!
Post #356746 13th Nov 2015 8:07pm
Clivefog
All sorted and nowt to pay out of my wallet, save for the Isle of Wight ferry and B&B plus fuel.
The motor just glided down the road despite the weather! 2 months on and still grinning like an idiot.
Post #359643 29th Nov 2015 9:46pm
