Home > Technical (L322) > Gearbox Cooler and pipes.
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Hi Folks.
A mate of mine is having gearbox problems which looks like it's caused by overheating. We have changed the oil and filter but the problem is still there. We are now thinking it could be a blockage in the cooler or lines?
Does anyone know if it's possible to flush out the cooler and lines and what is the best way to do it or is it best to replace with new components?
Thanks in advance.
Gary
Post #355810 8th Nov 2015 9:12am
wealy
I wouldn't mess about flushing
I would replace
Post #355812 8th Nov 2015 9:44am
holidaychicken
I replaced the pipes , cooler and oil cooler thermostat housing when I rebuilt my transmission and you need to make sure the bottom rows of your main radiator aren't blocked as it feeds the cooler as this is the common reason for the over heat
Island 4x4 was best when I did mine.
You could check the main rad first but for peace of mind for my new transmission I did the lot
Post #355819 8th Nov 2015 10:39am
Replace it is the only sure fire way sir Thumbs Up
Post #355833 8th Nov 2015 11:59am
Yep mine was the same, changed the oil cooler, both pipes, the manifold it sits in and it's thermostat, also changed the rad..
See this post for checking your mates rad....
http://www.fullfatrr.com/forum/topic28293.html Pete
Post #355841 8th Nov 2015 12:53pm
Garyfax
Thanks folks.
I will let you know how things progress.
Post #355890 8th Nov 2015 7:12pm
