Home > Technical (L322) > Tyre Pressure Monitors |
Andpopse Member Since: 16 Oct 2010 Location: Bristol Posts: 100 |
Can anyone tell me how I can tell if I have TPM. My FFRR is an 06 Vogue sc Supercharged. I assume this is a std feature, but need to confirm.
9th Nov 2010 10:27pm |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 |
You should have a light which comes on in the dash display when you first turn the ignition (bottom left corner, yellow - looks like a cross section of a tyre) - if it comes on with all the other lights then goes out after a couple of seconds once you have started the car - then you have and everything should be all ok - if the pressures are low on any particular tyre (including spare) the light will stay on and you will also get a message which tyre is low on pressure on the dash message display. |
9th Nov 2010 10:41pm |
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 |
Never knew it did the spare as well ! Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it |
9th Nov 2010 11:06pm |
Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142 |
Don't forget though, if you have a slow leak it won't pick that up. Has to be a fairly quick reduction in pressure.
9th Nov 2010 11:18pm |
How do they work??. The one's on our Mini use the abs sensors to detect of one wheel is dragging more than the others, and it seems pretty good at detecting a small drop in pressure. I presumed that if it also monitors the spare it must use some other hocus pocus Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it |
9th Nov 2010 11:31pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Wireless transceivers in the valves .... Btw, it is NOT a standard feature. Land Rover Addict
9th Nov 2010 11:44pm |
Each valve on the wheel is connected to a sensor of one kind or another which fits inside the wheel / tyre - it is all part of the same unit.
9th Nov 2010 11:45pm |
I thought it was standard after 2006 ? I have no idea if mine has it or not Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it |
9th Nov 2010 11:48pm |
If you have it, the MID unit will have a screen for it, and there is also a button/indicator on the centre console. It is not standard on any RR, it is a factory fit option. Land Rover Addict
9th Nov 2010 11:52pm |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 278 |
Erm ........
10th Nov 2010 12:01am |
Hmmmm. I have no button, or screen. But i do have a little warning light that looks like a cross section of a tyre with a warning triangle in the middle. It comes on with the ignition for a few seconds. Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it |
10th Nov 2010 3:29pm |
