Home > Technical (L322) > Are these settings editable?
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I have the L322 faultmate, I will check the settings and let u know
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #356015 9th Nov 2015 10:13pm
GraemeS
Australia
It appears that the Faultmate cannot effect CCF changes to the MY11/12 even though it thinks it can and results in what appears to be a bricked ecm, but fortunately only temporarily.
The ecm holds a copy of the ccf data but the Faultmate function to match the ecm ccf data with bcu data fails with an error, possibly because of lack of engine nomination for 3.6L or 4.4L so the command may not be correct for the 4.4L ecm. After writing the ccf or restoring a previous backup copy of the ccf then attempting to match the ecm ccf data with the bcu, the engine will not start until all instrument display messages are cleared using the OK button. I found the apparently bricked ecm unsettling but eventually stumbled on the cure.
Edit: BBS are working on a fix for a bug in their s/w so hopefully Faultmate will soon be able to make CCF changes to these vehicles.
Post #356161 10th Nov 2015 10:23pm
