![]() | Home > Maintenance & Mods (L322) > warning gong on start up from cold but no message |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
If you have waited till all the lights on the dash go out then confirmation that the self check has been done and all is correct.
Suggs Member Since: 16 Jul 2015 Location: Norfolk Posts: 94 ![]() ![]() ![]() |
thanks mate, ill check that out. just strange its not happened before the last few weeks, but sounds like your could be right as i remember seeing the battery light go out just after the gong |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
if the temp has been below 4 degrees then you'll get that warning.. ... - .- -.
Correct Stan although, as I understand it, you can set the temperature.
i dont think the temp point can be set John... ... - .- -.
I'll have to look at it. |
still did it today from cold after i left it a little while between ignition and starting for the lights to go out, drove 10 miles then was parked up all day on a farm, then did it again on way home only this time HDC inactive flashed up for a few seconds then went off. Drove perfect the 10 miles home then i stoped and started it again and it didnt gong. Defo only does it from cold..
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
I'd check the battery voltage... |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
low temp warning? 2004 L322 V8 |
It sounds like the low outside temperature warning. However when the engine is warm, the heat will get to the outside temperature sensor (when the car is sitting still) and "raise" the outside temp measurement.
thanks, makes sense as only started doing this since the weather got colder. And once engines warm it dosent do it until car left all day or over night.. |
ebajema and chex, you still asleep this morning...
Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Pete, they don't do cold in there neck of the woods, I'm not sure that they have grasped the concept |
