![]() | Home > Maintenance & Mods (L322) > Alternator change - how to release drive belt tensioner? |
| sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613
I don't know if it varies for the 4.4 but for my 3.6 and 300Tdi you simply put a socket and breaker bar on the nut and twist.
| tafftoo Member Since: 29 Jan 2015 Location: Staffordshire Posts: 40
How did you get the belt off in the end? I'm at the same stage and struggling to work out how to rotate the tensioner to get the belt off. Expansion Tank bracket was a right PITA |
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1532
Hi,
I gave up on the expansion tank bracket and just moved the tank out the way, stupidly located bolts on that bracket |
| acrr1 Member Since: 30 Aug 2015 Location: Thirsk Posts: 24
Not sure if it's any help but I've just removed the power steering pump on a TD6 and the tensioner nut for the belt is 24mm. I used a standard 24mm ring spanner. On the TD6 at least you can access it and tension/untension the belt without removing the radiator cowl. I just moved the belt out of the way, didn't take it off completely. |
I can't even seem to get at it to get the wrench properly on the flat bits, and when I do, there's no movement left in the wrench to even start to apply leverage... How much disassembly did you do?
Ah right, I took the fan off. I was able to 'flex' the AC pipe out the way and it was a fiddle to get the fan and shroud out but that's how i did it there really isn't much space there at all.
I've got the fan spanner but I was hoping I wouldn't have to take it all out. Oh well. I'll give it a go |
It's such a simple thing to remove you might as well as it frees up a lot of space. Ed |
Well, I've finally managed to get the alternator swapped, but when putting the new coolant in, I noticed that it was blue and not red... Typical! I've reason that the wrong coolant is better than no coolant especially in the short term, but does anyone know what kind of issues it will cause and how long I've got before I need to flush it and refill with the correct coolant? |
| SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459
Mixing the types is poss worse - it causes a reaction and leads to a sludge substance.
Booked in for Wednesday with LR to do it. I won't get chance until the weekend and I'm sick of messing with it after the alternator job.
Just an update... LR had my car as a 2005 4.4 BMW engined V8 on one of their systems which was why I was sent the wrong coolant. They've now double checked and confirmed that I'm not going mad, that I'm not missing or surplus a supercharger, and are doing the coolant flush and change at no cost to me.
Good to hear!
| All times are GMT |
