![]() | Home > In Car Electronics (L322) > Fuses td6 |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
There's a rubber bung in the bottom of the compartment where all the modules sit, you can remove it to let the water out again. |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Amazingly spare wheel well is dry, possibly the last couple of days weather has done the damage. Any links to a new seal or is it LR only item. |
The seal is LR only, best place to get is via Dan@Duckworths, forum sponsor. Just send him pm with your requirements. |
Had a good look today and it turns out the tailgate seal is OK, water has been getting in thru the side trim so i have removed it fitted new clips and sealed it, all seems to be ok now after 20 mins of hose pipe abuse. |
Latest update, Being a stubborn old sod i thought i would have another go at it today. I stripped the tv/entertainment unit and solder two wires to the PCB, then connected them to the loom the other side of the blue connector. And hey presto we have a monitor again. Next job is the radio, got it working but only for 5 mins ( switch it off and then on it works for another 5 mins ) I will keep at it |
Apart from the three plug in connectors on the amp i noticed there is a aerial type connector should this have something connected to it ?? |
How do i establish if my amp is the problem OR the BM54 radio tuner to my no noise music system?? Help please |
Although there is an aerial connector on the DSP unit nothing is connected to it.
Cheers niceday for your reply. im going to attack it again today, no doubt more help will be needed |
DSP is not coming up on screen, does anyone know to a amp for sale? |
Have you tried taking the casing off the DSP and looking for water damage on the rear of the sockets on the top.
Yes i have had it apart and all seems good and clean inside no sign of water |
http://www.fullfatrr.com/forum/topic30365....eplace+dsp I find that a little hard to follow |
