![]() | Home > Technical (L322) > Can water get into the rear footwell via the rear light? |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 614 ![]() ![]() ![]() |
Mine did this boot seal gone i would say ? silicone round it or get a new one cheep fix if it is that |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8762 ![]() ![]() ![]() |
The recess for the rear lights is sealed, no access to the inside of the car except the rubber grommet for the wiring to the rear light and it's very unlikely it will get it there... Pete
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
Thanks thought as much must be something else |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
Ordinarily it will be the boot seal... Check the top corner, it will probably have expanded internally and it will be leaking there sir |
So the boot seal looks new, i had a good look today and it appears to be coming from the rear 3/4 window of the left hand side, i spoke to my local dealer who said that is not uncommon for that to become de-laminated and need resealing?? |
