![]() | Home > Technical (L322) > Debutante with questions about iPhone/iPod |
doublejay Member Since: 08 Nov 2009 Posts: 131 ![]() |
I''ll kick it off, might neeed others to fill in :
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
DVD player is a 6 disc multi-changer in the boot. LHS as you look in the boot, behind a panel that is easy to remove.
I have a BMW based FFRR so I've played more with those - and I've heard and read conflicting reports about fitting the latest BT module to an earlier facelift RR and as to what a sw upgrade does with the contacts/voice control - sorry can't help there. I have full access to my contacts via the steering wheel buttons and voice control over the phone and nav (and full iPod control).
Greg66 Member Since: 11 Nov 2010 Location: London Posts: 84 ![]() ![]() |
Thanks for this, everyone.
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 744 ![]() ![]() ![]() |
If you have the Rear Seat Entertainment fitted it does have an AUX in port (only composite though) built into the back of the center arm rest, you could plug a video iPod or something similar to get additional video in. 2021 P400 Silicon Silver AB
Avi Member Since: 24 Sep 2010 Location: North West Posts: 309 ![]() ![]() |
Phone will work over BT, but contacts only if you have the later software or it has been dealer enabled. Hit and Miss, and you probably won't know until you get one whether it will work. I believe Wiggs on here will supply a new BT module on an exchange basis for about £60 if your contacts don;t work. I'm just about to contact him about mine, as i'm fed up of trying to use the voice recognition to call people. It only seems to work when i'm at a standstill. Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it ![]() |
Yeah, but as I said, earlier (BMW) system. I have the Intravee which works quite well - except the display times in large categories are somewhat slow. So if I'm looking for the 'Red Hot Chilli Peppers' I scroll to artist 200 of 240 and then wait to see where I am when the artist name appears. Playlists and album tracks work just fine. Suppose you can't have everything. My iPhone gets mounted and charged as in the pic above. And cell reception is improved through use of the GSM antenna. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
There's no need to put it anywhere neat as the ipod will be blocked when its working with the ACM. All you get is the LR symbol on the screen, so the best place to leave it, is permanently on the glovebox out of sight. As it charges itself with the car, you can just leave it there and never worry ever... 5 playlists is correct, and cd6 will be a gigantic playlist. The ACM just emulates a cd, so there's isn't any addicional funcionalities there. All you get is a CD with more tracks and the identification of the track. In adition you can control it like any other cd, you can use the voice commands to look up tracks and cd's, like '' cd4 track 5'', ''cdplay'' etc... The ACM module also comes with 2 other plugs, one usb por for a pen drive (similar functions, playlist cd1-5, all cd6) and another for RCA connectors, if you want to connect a turntable to the car.... ![]() ![]() But CD6 can also be emulated as a single playlist, just take it out of the car, do a search on ipod, or block it for a single album/artist, etc...and voila, you will just listen to what you want. In my opinion, it's not a perfect system but it beats a regular CD anytime. It's advantages clearly outweight the niggles. |
