Home > Maintenance & Mods (L322) > TRANSFER CASE OIL FFRR
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Hi
I am about to change both cars the Transfer case Box oil
LR parts have the oil as: SHELL TF0753
What no body knows is what grade of oil is it - as LR fills up little plastic bottles and puts a sticker on it saying
"Special Transfer Box Oil"
which is as good as a bar of soap !
now as my good LR dealer has quoted me £120 + VAT for each car to have its transfer oil changed - you can imagine that its such a little job - labour 10 minutes at tops.
Parts:
IYB500020 - Drain Oil Plug @ £ 2.35
IYF500030 - washer @ £ 0.54p
You can source the oil for around £24.00
But who know exactly what grade of oil is it ?
Castrol ? Grade ?
75W - 90 ???
I ve got a complete LR workshop manual - but at the moment I cant find it in here as its 3500 pages
both cars are 4.4 TDV8 - 12 year models
Thanks in advance
Just found this if it helps anyone:
http://www.disco3.co.uk/gallery/albums/use...ations.pdf
more info:
http://www.disco3.co.uk/forum/topic10978.html
Got to the bottom of this
It pays to know top people in certain companies - called the head guy I know who has confirmed:
Shell TF0753 is the same as:
Castrol BOT26 FMB1 Fully Synthetic Transfer Case Oil
GRADE OF OIL IS:
SAE 75W90 API GL4
suggest you check on all this yourself and research it too - but I am happy with my results
again - hope this helps anyone reading it
Post #355137 3rd Nov 2015 4:16pm
Zirconblue
You only need a litre of it, and a litre bottle from LR is about £13. I did mine a few months ago.
Hardly worth shopping around for that price. But yes it was Castrol and has the specification on the bottle.
The auto gearbox fluid however is a different matter - LR Want over £20 a litre (5HP24) for that stuff and you need 7 or 8 litres! You can find the same stuff half price in identical Mobil branded bottles!
Post #355162 3rd Nov 2015 5:35pm
EmiratesA380
Hey Zirconblue
Thanks for the update - noted
Post #355166 3rd Nov 2015 5:39pm
Zirconblue
no problem, the picture above is just a generic one, the actual bottle was a castrol 1ltr one (all be it trade/industrial labelled rather than flashy retail labelling) in a land-rover box.
I don't remember changing the bungs on mine, i think it was just two alloy washers. (unlike the gearbox bungs which have bonded on seals)
Post #355168 3rd Nov 2015 5:42pm
Yep - Just buy it from dan, wasn't that much tbh when I changed mine a few years back.
According to Microcat the part is IYK500010 and is listed as Shell TF0753 rimmer bros have it too.
http://www.rimmerbros.co.uk/Item--i-IYK500010 There is nothing that can't be fixed with a hammer😜😜
M3 3.2 EVO Convertible Techno Violet
Post #355170 3rd Nov 2015 5:46pm
EmiratesA380
Zirconblue
Workshop manual says if any help in future:
capacity - Wet and Dry fill 1.5 Liters (2.6 pints ) (1.5 US quarts )
Input shaft splines grease - Weicon TL7391
Transfer Case
Model: DD295
2 speed, permanent four wheel drive transfer box having synchronized shaft on the move facility with an actively controlled wet clutch and 50/50 torque split across the centre differential.
Clutch Type: Wet, multi plate
Max Torque capacity: 2500Mn
Ratios: 1:1 ( low 2.93:1)
High to low ratio = 40kph ( 24.8 mph )
Low to high ratio = 60kph (37.2 mph)
Transfer case fluid Drain Plug M16 = 22NM
Transfer case fluid Filler Plug M16 = 22NM
Transfer case fluid Drain Plug M18 = 28NM
Transfer case fluid Filler Plug M16 = 28NM
Transfer case shift motor bolts = 45NM
Transfer case clutch control solenoid bolts = 5NM
Workshop manual also states:
Refill transfer case with recommended fluid, until the fluid is level with bottom of filler/level plug hole.
INSTALL A NEW SEALING WASHER
Install the fluid/level plug and tighten to ( see torque settings above )
Post #355173 3rd Nov 2015 5:52pm
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Purchased my transfer box oil today from advanced. Just wondering if anyone knows the amount needed, the bottle I got contains 946ml which I'm told is enough. I don't want to end up being short.
Post #357724 19th Nov 2015 3:44pm
From memory it require around 1.3 litres I think Big Cry
Post #357729 19th Nov 2015 4:07pm
John is kinda right
but i dont think you will get all the oil out so maybe your amount will be enough Gary.. ... - .- -.
Post #357730 19th Nov 2015 4:13pm
Garyfax
Thanks Stan. I will let you know how I get on.
Post #357732 19th Nov 2015 4:34pm
ryan did his 4.2 and 1.3 litres came out,
http://www.fullfatrr.com/forum/post313441.html#313441 ... - .- -.
Post #357734 19th Nov 2015 4:39pm
Lost for Words
You will need more than 1 litre I'm afraid. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #357735 19th Nov 2015 4:39pm
Garyfax
Thanks guys. I've just ordered another 1L tub.
Post #357737 19th Nov 2015 4:48pm
Zirconblue
Earlier ones are only 1ltr fill from dry or 0.96ltr refill.
They presumably changed the transfer box with the 6 speed gear boxes. Smile
Post #357789 20th Nov 2015 12:04am
Advanced Factors
Site Sponsor
If you look at our website we list oil grades and quantities in the service item section for each model.
I have given up telling people to use 75w90 for transfer boxes and simply list it as the Shell TF0753. I did this research a long time ago and found it to be basically 75w90. However I got a little annoyed with so many opinions from forum experts telling me I was wrong. (Not this forum I might add)
Needless to say my Magna Steyr runs on 75w90.
LR have a habit of hiding true grades and even on Microcat they refer you to the Castrol website for data, once on the Castrol site they refer you to the dealer for the correct oil. Nothing like running a closed shop on data is there! Paul Redding
+44 (0)23 8052 2760
paul@advancedfactors.co.uk
Post #357809 20th Nov 2015 8:31am
