![]() | Home > Maintenance & Mods (L322) > A few probs with my L322 |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 ![]() ![]() ![]() |
Hi Everybody!
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Probably can help on a couple.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Hi, you probably need a new battery which should sort a few problems.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8025 ![]() ![]() ![]() |
This thread might be of use then ![]() The battery can cause any number of other warnings, so if you think its getting on a bit, always worth changing - the FFRR is fairly fragile where batteries are concerned. Beyond that, nothing sounds like a DIY job for you, so better to find someone who knows the cars well and put your trust in them. |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Re parking sensors.
From Coventry you will be about 90 minutes from Cam Tech LR in Gloucs... If drivable, it might be a worthwhile day trip out to find out 'where your car is at' mechanically |
Thank you for your advice, but things have moved on slightly.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
The parking sensors do exactly that! Very frustrating!!! A little tip, when you find the one that does NOT click... Change it with the neighbouring sensor and see if the fault moves... If not, first check the wiring sir |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
At one stage my reversing |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It sounds like it has other problems too. But i have read on here the early TD6's came with 18" wheels as standard, fitting larger ones makes them resonate/vibrate when sitting at lights - so has yours had big wheels fitted? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
im sure you know, but there is a switch on the lower left of the upright centre panel, to disable and enable the beeps. just check the manual to familiarise yourself. i use it in traffic, as sometimes you get someone up your backside, or they are wet and are seeing a blob of rain. i think they automatically re-arm on new start-up of engine etc. and go off after 10mph etc. sounds like you connected the battery up very wrong, to either get a full short accross it, or the other battery. or you connected them in series, and turned it into a 24v supply. -maybe a little less considering other batttery. sounds like you have been lucky so far. next time though, its red to red. or +red to +red etc there is often a little sparking as you connect them. but only like flicking a lighter! you nearly had a 500amp 'lightbulb' there. |
FYI it is possible to short the positive jump lead on the stud that pokes through from the suspension, be very careful when connecting the + positive clip, I had a lucky escape with mine. The design of the whole system is
Thank you JohnBoy, but no, I didn't know about the switch, I will take a look when I get the car back because......
Hello to anyone who is interested. I did have THREE injectors replaced and that has made the engine run smoothly, thankfully.
