![]() | Home > Technical (L322) > High speed breaking seems wobbly |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8111 ![]() ![]() ![]() |
Something is wrong - it should brake smooth & straight - mine have always felt like I could brake without holding the steering wheel - no wobble or pull to either side on a flat piece of road.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
^as above, wheel nuts then check the rear calipers for excess heat after a run to see if one is binding. Next is to check the discs and pads all round then onto bushes ball joints, and track rod ends. Any and or all can cause the judder. There is nothing that can't be fixed with a hammer😜😜
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Sticking caliper slide pin is also possible cause. John
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
I checked the wheels for excess heat as I'd read it was an issue sometimes on the rears but all seemed about the same. The discs have a bit of a lip on them and pads are getting a bit low so will change the as out first as they will need doing anyway and see how I go from there! I didn't think it seemed right to be honest.
The clue is in the description - "slide" |
Thanks joe will just replace the discs too as they are fairly old looking at them, at least I will know that I have everything new on all corners! Don't want to take any chances topping something that size! Hopefully that will resolve the issues if not its onto the suspension checks.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Had the same issue on mine, rear caliper pin was tight. Wasn't even too bad to be honest but made a huge difference once freed off. |
It's generally not the calliper itself which sticks, it's the caliper carrier which corrodes and grips the pad which stops it freeing off when you take your foot off the pedal. |
Well I have now replaced the front discs and pads and they were all fine the back ones were a different story.
I'm trying to remember, but I'm fairly sure I had sticky rear callipers on my 07 - they needed replacing but think they were refurb units & I had to return the callipers that I removed.
The Pins are part of the caliper carrier not the actual caliper itself. to get them you will need to buy that not the piston part. |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
if a Blow torch and a suitable drift wont do it, then it;s probably a case of getting a new carrier. |
Phil303 Member Since: 23 Nov 2015 Location: East Anglia Posts: 47 ![]() ![]() ![]() |
Definitely brakes. I had something similar in my old S8. Only happened at high speed braking; pottering around town it was unoticeable. |
Thought I'd give an update incase anyone else has similar issues. Managed to free the pin eventually using lots of persuasion and some home made penetrating fluid made up of ascetone and atf fluid which did the trick! Also used joe 90's guide and do the rear brake lines which were exactly the same on the tdv8 as the td6 so pretty easy! The braking issues have now gone and no more wobbles so was definitely the sticking calliper pins causing the issues!
