![]() | Home > In Car Electronics (L322) > Reversing camera fuse |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 ![]() ![]() ![]() |
Battery reset sir |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
Thanks Craig. |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi
Thanks RP |
dvb247 Member Since: 22 Nov 2015 Location: Cheshire Posts: 93 ![]() ![]() ![]() |
I have no image on my rear cam as well, where is the rear fuse board so I can check the 5 amp fuses?
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3204 ![]() ![]() ![]() |
Right hand side of boot behind the removable panel. John
No 5 amp fuses have gone, it may have been swapped for a higher amp fuse though, I will try and post my rear fuse box, hopefully someone here can guide me, cheers!
What's that Craig in layman's terms? Will be checking tomorrow if its a 5amp in number 8, which is the number fuse for the reverse camera ![]() |
Thats not good, my fuses seem to be different ratings from what the manual says they should be on at least 50% of them, so fuse number 8 sopped to be a 5 amp, it's not, it's 30amp same as number 9??? |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1199 ![]() ![]() |
^ Funny that - my last FF (also 06 MY) had virtually no fuses correlating to the manual (!)
So it looks like I need to check the tailgate to see if the wires have broken or unplugged?
