![]() | Home > Technical (L322) > Forward Alert not available - dashboard msg |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35698 ![]() ![]() |
a glitch because of a low powered battery.. ... - .- -.
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
+1 for above, battery on the way out |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
practically a brand new battery and the car had just done a 150 mile run the night before. so battery should be in good order.
i think its a typical FF problem where if the battery is a bit low [for what ever reason] when you start up some of the ecu's dont get their full power allocation so that particular ecu function wont work properly..
I had a similar issue (spurious messages, not F/W Alert as that wasn't on earlier models) on my previous 2006 S/C and it was caused by a loose battery connection, so worth checking if it has only recently been replaced |
all connections (visible) all seem solid and tight.
dont know re the diagnostics but a hard battery reset might work.. ... - .- -.
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 133 ![]() ![]() ![]() |
I don't know about the L322 system, but my Jag XK8 had the Forward Alert system that packed up. It turned out to be the brake switch. Once a new one was fitted, all was well. Like I say though, not sure if the L322 works in a similar way, but perhaps worth keeping in mind.
yep - tried again this morning, still getting the same warning msg. Something more related to the forward alerts system me thinks rather than battery. (though with these cars I stand to hang my head in shame |
Disconnected the car battery and reconnected an hour later - no joy warning - message still shows on dash.
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
To do a hard reset you need to short the terminals together for a few minutes (obviously not with the battery connected!). |
Yes, basically this drains the ECUs and gets them to start up from scratch. One thing I forgot to say - you need to have the ignition on too. |
errrrr....
