Home > Technical (L322) > just a quick one. again
thegamekeeper
2006 Range Rover Vogue Td6 Java Black
hi
just wondered if anyone can help me please. i think my motor leans to over to the passenger side. the wife says it doesnt but from where im sitting it seems to leen over slightly. ive been told theres a way to check this using the screen but that beyond me. im now paranoid about it leaning and everytime i look at in i think its leaning. theres no leaking air sound and the suspension lowers and raises ok. is it me am i goin nuts
thank you
tony
Post #358324 23rd Nov 2015 7:41pm
You need the above and then measure each wheel in turn, centre of wheel to underside of wheel arch.
Side to side should be the same.
Front to rear should be about 15mm low at rear compared to front.
Post #358329 23rd Nov 2015 7:52pm
thegamekeeper
just measured them and they are different
FNS. 495 mm
RNS. 475 mm
FOS. 510 mm
ROS. 485 mm
now what do i do. thats propper done me head in that
tony
Post #358343 23rd Nov 2015 8:24pm
viper
take into an Indie for a diagnostic and if the sensors are working ok it may just need a calibration like mine has just had. the differences in my heights were the same in all the levels ( access, road and off road)
Post #358346 23rd Nov 2015 8:36pm
these must be measured on a completely flat surface tony....if they were then you need to get an iidtool to set it up properly. ... - .- -.
Post #358347 23rd Nov 2015 8:37pm
thegamekeeper
i can do most things but when it comes to technical stuff like that im useless. ile ask about for someone who has one. would the landrover dealers take my eyes out to recalibrate it
Post #358355 23rd Nov 2015 8:53pm
Also note you may only get to within 10mm side to side as this is apparently an acceptable tolerance (well, with the IID tool)
Also easier to refer to as:
FR, FL, RR, RL (left (L) and right (R) is as looking at the car from the rear to the front) .
Post #358362 23rd Nov 2015 9:14pm
As Joe said they are totally acceptable, tolerance is + or - 9mm, you could possibly get them slightly closer but it's really not worth paying someone to do that, you will know if a height sensor gives up, the wheel is either all the way up or all the way down, they don't get progressively worse they just stop working.... Pete
Post #358363 23rd Nov 2015 9:19pm
mzplcg
LR would want about an hour's labour for that so probably not the end of the world, but it's only basic maths. With an IID tool you can see what the current settings are and once you've measured it you add or subtract from the values on IID and re-program the car to those values.
Worth checking the height sensors too. Semi-seized, or not giving accurate readings will make weird things happen. 25 odd quid each so again, not the end of the world. When I had one go on my 07 I just replaced all 4. Placebo effect possibly but it felt a bit crisper in the corners after that.
Post #358365 23rd Nov 2015 9:28pm
viper
my indie charged me £50 , this was an 1/2 diagnostic on his automate to confirm everything was working ok and that included my return visit to actually do the calibration which took about 40 mins ..
before I took the car in I checked my own airbags for leaks with soapy solution in a trigger bottle. I did a visual check on my sensors , all looked clean and in working order. the diagnostic check confirmed good volt readings from the sensors.
if your compressor is not continually running and the measured error is the same difference in the different height settings you could well be lucky and just need a recalibrate
even a new sensor is fairly cheap .
Post #358429 24th Nov 2015 12:18am
thegamekeeper
thanks lads. little things bug the life out of me. ile get them read and take it from there. ile let yous know how i get on
Post #358441 24th Nov 2015 6:03am
thegamekeeper
just called a garage to book it in and the bloke says its normally down to a bent rod (whatever that is ). booked in for saturday. is a bent rod something it could be or am i gona have me pants pulled down
Post #358459 24th Nov 2015 11:27am
Is the garage you called a main dealer / specialist that understands the car & air suspension ?
Post #358481 24th Nov 2015 12:55pm
thegamekeeper
hes not a dealer but word ishe knows his stuff. he too has a vogue and a garage around our way takes all his landrovers to him as he works on them and has all the tools and software. i know that means nothin. another landrover specialist has just quoted me £80 plus vat to plug it in his machine to check it
Post #358482 24th Nov 2015 1:00pm
I think he's talking about the rods which fit onto the height sensors, bit difficult to bend them as they are plastic.
If your going to keep the FF then buy yourself an IID or similar, what you need to do is easy to do and just involves pressing buttons, the IID will pay for itself very quickly, even if you don't do the work yourself you are protecting yourself by not getting ripped off by garages for other repairs it will need.... Pete
Post #358485 24th Nov 2015 1:14pm
