Home > Maintenance & Mods (L322) > 4.4 v8 plugs??
Steadfast
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
4.4 v8 plugs??
Sorry chaps
Will have been covered a million times before, I am sure. But did a quick search and couldn't find anything immediate, so quick question to you all, which plugs best for the old girl. 2003 4.4 vogue. Mate recommended these NGK BKR6EQUP. But these aren't what 'Rave' recommends.
Thoughts please.???
Steady.
Post #358586 25th Nov 2015 12:23am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Different versions of RAVE have different answers.
Main difference
NGK BKR6EQUP = 4 earth electrodes
other one 2 electrodes.
Only real difference 4 electrode one longer life (since it has 4 electrodes to burn down)
I have NGK BKR6EQUP, fitted in mine (same car as yours) but I would likely change them well before end of life (IIRC 80000miles something like that) Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #358639 25th Nov 2015 12:34pm
Steadfast
Many thanks Smutt.
I thought I might give them a go. Just wanted to see if anyone else had tried them.
I had read about a chap who used them and got better mpg from his lpg setup.
Cheers bud
Post #358782 25th Nov 2015 8:29pm
johnboyairey
my lpg guy said lpg setups, should not use the four prong type, you could, but got a better burn with a single type i cant remember but i have a plug box somewhere. mine were about £55 the set
Post #358784 25th Nov 2015 8:32pm
Steadfast
Thanks for that Johnboy.
So better burn on lpg or standard? Sorry mate.
Post #358790 25th Nov 2015 9:34pm
johnboyairey
I'm pretty sure I got a single electrode plug, but I will search my box of crap, as I kept a plug box, to reorder. (One day!) I will have a look and get back to you. I think the science is, a slow burn, is a better burn on the LPG. And one electrode helps to slow burn.
I have prinz LPG, if it means anything though.
Post #358831 26th Nov 2015 12:07am
Best plugs for LPG are standard NGK single electrode, none of these fancy plugs are any good, they claim they are but it's just to sell you the plug, people will say their mpg increased but that's just down to new plugs anyway... Thumbs Up Pete
Post #358837 26th Nov 2015 12:40am
Steadfast
Thanks chaps.
And best plugs for standard petroleum setup? What do you have in yours?
Post #359060 26th Nov 2015 8:08pm
Zirconblue
Most of the expensive plugs are just designed to last longer, rather than work better. It's why the service interval is so long on the expensive OE style.
If you replace them more frequently then there's no point shelling out on expensive ones.
the 4 prong NGK's i pulled out of mine shortly after i'd bought it didn't look like they'd been changed ever, going by the state of them.
Exactly, and it's rare anyone just changes the plugs on their own, it's normally part of a wider engine service - which in turn helps MPG and performance too. Even just cleaning up old plugs with a wire brush gives a slight improvement, to a point.
Post #359075 26th Nov 2015 9:53pm
Zirconblue
Duplicate post (site crashed)
Post #359076 26th Nov 2015 9:53pm
Zirconblue
Post #359077 26th Nov 2015 9:53pm
Zirconblue
Steadfast wrote:
Thanks chaps.
Mine just has cheap Britpart ones in it at the moment they seem fine, not sure i'd leave them in there for 80k but they should be good for a couple of years i would think. £2 each vs. £25 each for genuine. And they cant be worse than the cracked and erroded NGK's that came out of it.
Post #359231 27th Nov 2015 6:43pm
SMUTT
Due to the laws of physics, the spark will only ever go to one electrode at a time
4 just means that they last longer, once the longest earth electrode has worn down, the spark jumps to the next longest one and so on - gradually decreasing the earth electrodes length
I got the 4 electrode one since that was what was in before and it ran ok. But I would change them in say 5 years well before End of Life so getting a cheaper one would work just as well. Howard
Post #359243 27th Nov 2015 8:12pm
Zirconblue
on at least a couple of mine the centre electrode had eroded, the ceramic insulators were cracking too. God knows how long they'd been in there!
Post #359248 27th Nov 2015 8:39pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
is there a consesnus on the best/go-to plug for 4.4 petrol (0Cool jag engine? 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #359935 1st Dec 2015 3:32pm
