Home > Maintenance & Mods (L322) > Gear selector issues
I've noticed that over the past few weeks that my gear selector has been stiff when moving between P and D when the car's cold.
I've also noticed that even the slightest forward pressure will knock it out of D and into a false neutral. It seems that even a couple of mm movement is enough for this to happen.
Anyone got any thoughts? Got - 2017 SDV8 Autobiography in Loire Blue
Post #359192 27th Nov 2015 2:56pm
could the gear connections under neath be needing lubrication.. ... - .- -.
Post #359202 27th Nov 2015 3:11pm
I'm thinking that Stan but was hoping this had been seen before. I read that on the petrol cars, there's a linkage mechanism bolted to the outside casing of the gearbox but it's inside on the diesels.
Perhaps a liberal spray of WD40 (other lubricating sprays are available Whistle ) might help, just need to know any spots I need to avoid. Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #359204 27th Nov 2015 3:15pm
avoid you eyes, that hurts.. Shocked Laughing
mine being petrol indeed has the linkage outside but i didnt know that diesel ones were hidden.. ... - .- -.
Post #359210 27th Nov 2015 4:02pm
RRPhil
You’re thinking there of the earlier models with the 5-speed transmissions where the inhibitor switch on the GM 5L40-E (diesel models) is inside the casing whereas for the ZF 5HP24 (petrol models) it’s on the outside. You have the ZF 6HP26 transmission and, as Stan says, it sounds very much like the cable clamp has seized in its hole in the selector lever underneath the car preventing it from articulating as the lever moves through its arc.
Phil
Post #359212 27th Nov 2015 4:06pm
Thanks Phil, you're a champ. I'll take a look tomorrow Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #359223 27th Nov 2015 5:42pm
Mikey
Exactly the same procedure as here: http://www.disco3.co.uk/forum/topic31656.html
Post #359258 27th Nov 2015 10:30pm
Cheers Mikey. So those part numbers in that thread are relevant to my car too? Got - 2017 SDV8 Autobiography in Loire Blue
Post #359694 30th Nov 2015 1:03am
