![]() | Home > Technical (L322) > Reset Inspection warning |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Its in the Wiki section |
dvb247 Member Since: 22 Nov 2015 Location: Cheshire Posts: 93 ![]() ![]() ![]() |
Have checked and it's only for the 2002 to 2004 model, mine is a 2005 ??
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Mine is MY 2005. The method in WIKI is what I have to use. Later models can be reset with a diagnostic tool such as Gap iiD. The tool doesn't cover 2005. John
From what I've just read, my car is a 4.2 Jag engine with touch screen nav, which means it can only be done using a diag program |
For clarity is your VIN number 5Axxxxxxxxxx or 6Axxxxxxxxxxx ? If the latter then you would be better listing your FF as 2006 as it helps with answering any queries you have. John
Not got the logbook back yet, can only find the SALLMAM number on the windscreen and under the bonnet on the strut. do you know where I can find it? |
It's the number at the bottom left of the screen. It's the rest of the number after SALLMAM.
Doh, sorry, yes it's a SALLMAM336A209***
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Just for future clarity.
Thank you |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
All 4.2’s are 6A> i.e. Jag engines signify 06> builds... |
