Home > Technical (L322) > Diesel tuning boxes and MPG adjustment
Zigzagsky
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Just been thinking about these devices and I'm aware that compared to a proper engine map they are a poor cousin but they do have the advantage of being easy to fit and remove if necessary.
But here's a question which I'm not sure has been answered...
They give a better performance due to fooling the system into thinking the actual fuel rail pressure is less than it is.
So with regards to the claimed improved MPG, would it be fair to say that the system will also fool the car's ability to determine the actual fuel consumption.
In other words, is the 'better' fuel economy of these devices down to the fact that the displayed MPG is higher which is no longer an accurate representation (not that it is normally but you get my gist) and that the actual MPG is pretty much the same?
has anybody tested this doing the 'brim to brim' test?
Post #359739 30th Nov 2015 11:50am
The ECU calculates fuel used by measuring the injector opening times, not the pressure in the rail...
Had one on my old Volvo and it definitely gave more MPG when measured the old way... brim to brim... Pete
Post #359748 30th Nov 2015 12:14pm
Lost for Words
A tuning box won't give better fuel than a remap, indeed, it's much more likely to use more fuel than standard than a remap is. You also loose the safety buffer with limp mode, sould the engine develop a fault. A good, reputable remap is the only advisable option IMO. Thumbs Up Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #359749 30th Nov 2015 12:14pm
Zigzagsky
OK, that's interesting regarding how the fuel consumption is calculated. Thanks for the clarification.
Post #359756 30th Nov 2015 12:39pm
Rangie in oz
United Kingdom 2003 Range Rover Vogue Td6 Epsom Green
Ive fitted a tuning box to my TD6, totally transformed the car, it claimed 10% better economy and according to the on board computer its right. the improved mpg comes from more torque and not having to press the throttle as far 03 TD6 vogue....Epsom, very nice
03 TD6 se....gone Sad
94 Vogue se....gone Sad
Post #359761 30th Nov 2015 1:17pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I had one on my D3 2.7 and made a big diffrence, but the more you go! The more you drink as the saying goes Razz Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #359776 30th Nov 2015 2:26pm
