Home > Maintenance & Mods (L322) > Water ingress rear door
Clivefog
I've only had it 6 weeks and twice in that time I've opened the rear driver side door and lets about a cup full of water out. It is sitting on the bottom outside of the seal, is it a common problem and how can I resolve it?
Post #357307 16th Nov 2015 7:32pm
Very common... the search button is your friend.... Thumbs Up
http://www.fullfatrr.com/forum/search.php?...rch_time=0 Pete
-Click here for Thread-
Post #357314 16th Nov 2015 8:07pm
Clivefog
Thank you kindly. I'll try the block of wood method first.
I did do a search and found nothing of relevance to the rear door, hove now thank you again.
Post #357449 17th Nov 2015 6:31pm
Thumbs Up Thumbs Up Pete
Post #357482 17th Nov 2015 8:36pm
Clivefog
I used the front part of a trainer, small amount of pressure and no problem so far.
I just love the cheap fix, well nothing in this case and I used the wife's trainer
Post #359646 29th Nov 2015 8:52pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Well done and thanks for posting result to help others. Is SWMBO's trainer available for others with similar problem. Rolling with laughter Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #359690 29th Nov 2015 11:23pm
Clivefog
They live in the boot and are free to use I'll just charge mileage.
Before I did anything I just pressed the top rear corner of the door on both sides, near side minimal movement the offside was more noticeable after just a gentle push all is well.
Post #359808 30th Nov 2015 4:07pm
Weegie
Was that her personal trainer or footwear? Whistle Very Happy Very Happy John
GAP iiD BT-Sold
Post #359811 30th Nov 2015 4:11pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Does it work better if the foot is still in the trainer?
Post #359812 30th Nov 2015 4:19pm
Clivefog
The PT could not get his head in the door.
If there is a foot in the trainer it may dent the door frame, although if it is someone touting for PPI may well be worth it!
Post #359882 30th Nov 2015 10:06pm
