![]() | Home > Technical (L322) > Forward Alert not available - dashboard msg |
| Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473
Good point actually; I'm not sure (oh dear me...what was wrong with the simple key?! |
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Or leave the live connected to the battery , disconnect the earth lead, then connect a wire from the live lead to the disconnected earth terminal lead and that will drain the residual power |
| comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764
I don't, sorry but when mine goes into a fault with the forward alert the adaptive cruise no longer works (they do use the same radar)
| Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409
no worries folks - guess I'll book it in at the local dealers to see what they say it is.
Well - with still about 2 weeks to go before the dealer will look at the problem.....but....
| Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266
Fleagle_UK
Afraid not. It behaved itself after that. All I could guess was just a software glitch. |
| ifelton Member Since: 18 Jan 2021 Location: Merseyside Posts: 1
Hi guys, did anyone else find what is causing this as mine is doing it now. |
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
On mine one of the height sensors is going bad (new one on order). When it loses the signal (and you can see it "drop away" on the 4x4 info screen) the suspension alert comes in. That then knocks off the forward alert and cruise control as well.
