![]() | Home > In Car Electronics (L322) > CD changer replacement - one for GAP possibly |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Ł600 ish Pete ![]() |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Looks interesting. Also that the CD player can be retained if wanted. As I understand it it is inserted in the MOST circuit at any point so if all one wanted to do was use a USB stick it could be inserted in the boot so avoiding all the stripping out to get to the CD? Personally all I want is to be able to play music from USB and a large one (they quote up to 64Gb) would fill the bill and avoid any inconvenience of having to frequently change the USB. All the other requirements - phone etc - are adequately cover by the standard system for me. John 2008 Stornoway Grey 3.6 Tdv8 Vogue - SOLD 2005 TD6 Java Black Vogue - Written off!! GAP iiD BT-Sold |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35700 ![]() ![]() |
so this russian thingy costs 229 euros which is about Ł161....shipping is 6 euros... ... - .- -.
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
Looks interesting, but my Charman is not up to deciphering the fitting instructions. |
its plug and play steve.. ... - .- -.
Steve, The optical circuits pass through each element in the line so unplug one side of one.
forever Member Since: 06 Oct 2015 Location: Oxted Posts: 319 ![]() ![]() |
That's how I read it too. I would take out the 6cd changer and replace with this, you could also plug in a Bluetooth USB dongle to get Spotify etc from your phone.. |
Doh! |
Ack-cherly, I thought at first it was Plug 'n Play (he said, trying to sound convincing |
Just had a look at the instructions (Google's Jairman was enough to understand |
I hadn’t dared say any more as I bow down to the superior knowledge of forum members |
If you remove the CD player then one MOST connector for the new unit would be sufficient. The MOST connectors on the RR optical circuit have two fibre optic cables going into them. One carries the signal into the unit it is connected to and the other carries it away into the system (for want of a better description). IIRC the direction of travel is marked on the connector.
