Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'd hope so, discovered that a bloody candle was brighter than the standard lights I still find it hard to come to terms with how they managed to get it so wrong with the reversing lights in the first place, after all your allowed 21 Watts per side under euro meddling laws, so why opt for 6 watt bulbs? they must have had a balls up in the purchasing department and ended up with a lorry load to get rid of......... only logical reason I can see Maybe they were destined to be instrument lamps but they were so dim they thought they'd get rid of them in the Range Rover, who knows how the German mind works, get a feeling that they were laughing at every under powered car that left the factory But we can have the last laugh, as the led upgrade is way better than anything you'll find on the rear of an X5 Yesterday I couldn't spell Engineer... Today I are one! Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
3rd Dec 2015 12:28am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16192 |
Great job Dave... Much brighter |
3rd Dec 2015 1:00am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3956 |
The bulbs I purchased were from Hong Kong and took two weeks to arrive.
3rd Dec 2015 10:47am |
^^ 12v AC is for low voltage domestic lighting, and will have a built in bridge rectifier Yesterday I couldn't spell Engineer... Today I are one!
3rd Dec 2015 10:55am |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Unnecessary quote removed
3rd Dec 2015 2:25pm |
Just bought the 5w version (says 6 but it's 5w on eBay). Wanted to go the cob route since I think it will be a bit brighter than the little leds. The entire length of these are 40mm so they should fit fine. Now just need the washers and G4 sockets
3rd Dec 2015 6:07pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 314 |
So after 216 posts we still don't have a simple plug and play mod, we have all failed but not through lack of trying 😃😃😃😃 Many thanks
12th Dec 2015 9:05pm |
I can do a simple plug and play version, but, I will have to buy the lamps from Land Rover and that is were the problem lies, there wont be much change out of £100 Yesterday I couldn't spell Engineer... Today I are one!
12th Dec 2015 9:25pm |
Cheapest and best option is send the Misses round the back with a big torch then 👍👍 Many thanks
12th Dec 2015 9:49pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
No point my misses is only 5" so no improvement over the car Current vehicles
12th Dec 2015 9:53pm |
Jeese 5" what's here name Barbie 😜😜😃😃😜😜 Many thanks
12th Dec 2015 9:56pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Miggit, what about a used donor first set, then do a buy and return your old set deal |
13th Dec 2015 3:29pm |
I did think of that, but having found that they can get brittle, discoloured and cracked with age, it would be impossible to guaranty the quality, and would therefore be laying myself open to "I want my money back as my lights were better than the ones you've sent".
13th Dec 2015 5:45pm |
Points taken |
14th Dec 2015 8:13pm |
