![]() | Home > Technical (L322) > Battery drain......sad face |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 ![]() ![]() ![]() |
Due to not being able to do the red light check on the sat nav can anyone tell which fuse it is? I downloaded the PDF for the guide but I can't see which is for the sat nav or is that because it's not on its own and is with other items?
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Haven't read the entire thread but what year and model is it as if you have headlight wipers these can fail to home properly and drain the battery |
Range Rover Vogue HSE 2006. No headlight wipers on my car thou.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8736 ![]() ![]() ![]() |
Does your sat nav work?? and your confusing me, it's EITHER an HSE or a Vogue.. if it's a Vogue it should have wipers, you say it hasn't, if it's an HSE it shouldn't have sat nav....!!! maybe it's an HSE with extras... does it have a heated steering wheel and REAR heated seats???
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
If its on 05 /55 (6A) it will have no wipers and a touch screen (like mine) it's on the cross over
Oh yeah... doh.... still can't be an HSE Vogue though.... Pete
***update***
Tom Paine Member Since: 11 May 2015 Location: Townsville Posts: 47 ![]() ![]() ![]() |
I had exactly this. Battery went from full to flat in about three days. Car electrician found the electric cooling fan had got a dead short. Fan replaced and all is well. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
rangeseb, don't worry about not having headlamp wipers, when LR did the face lift in 2005 they ditched the wipers and went for a jet wash system instead |
Miggit.....
It could be any number of things, you do know that there are 3 fuses for the nav computer? My nav head was going in to one the other day so I pulled the disc to stop it constantly trying to load it, clunk whirr all the time from the back, was driving me nuts! A pal of mine has had trouble with his FBH (Aux Heater) it keeps on trying to kick in, hours after the car has "gone to sleep". I don't believe that they go to sleep, I think that they just lay dormant waiting for the best time to strike |
***update***
***update***
