![]() | Home > In Car Electronics (L322) > AV System completly crazy |
| HUGI Member Since: 23 Oct 2010 Location: Jona-Rapperswil Posts: 244
Hey Folks
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
If it's better when it's hot than cold then it is probably a dry joint somewhere causing the problem....
It is not really better when its warm I would say..
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
check the battery or loose battery connections Phil... ... - .- -.
just checked (car was parked in the garage for 5 hours)
In the hidden menu? (is this available on the 06 ? ) or you mean the 753? (next time when the system is in a good mood and works, I will try to get in this one to check)
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790
Yes, 753 menu, under vehicle signals. There is nothing that can't be fixed with a hammer😜😜
so let me report back from the shop..
ohh folks.. By the way..
Update after a week in the shop. They checked out EVERYTHING!
| All times are GMT |
