Home > Maintenance & Mods (L322) > First Failure
steadyaway
First Failure
Well, 11 months into ff ownership and it's broken! Luckily it looks like it's only the ignition switch. I've asked Dan for a price for a replacement but while I'm waiting I'll strip it down and spray it with contact cleaner to see if that helps. Other than that I've been absolutely suited with it, it really is a pleasure to own and drive. 😆
Post #360446 4th Dec 2015 10:07pm
What makes you think it's the ignition switch, what are the symptoms...???? Pete
Post #360518 5th Dec 2015 2:59pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
When mine went it was intermittent, it started most times but then not on others. When it didn’t work I got a strange couple of bleeps from around the key are (very faint) . I replaced the lower half of the switch and had no problems since (touching a large piece of wood at the moment!!) Good old Dan to the rescue!
Cheers
Simon
Post #360520 5th Dec 2015 3:13pm
steadyaway
It's the same syptoms as others have had. Intermittent failure to start. Beeping, whirring and clicking from the the area around the key. Twist the key to off then run repeatedly and it may crank eventually. When it cranks it fires immediately. After doing a search it seems I'm not the only one. Some have cleaned the switch with success and others have replaced it. I have decided to replace it so it won't fail when Mrs me is driving it.
Post #360555 5th Dec 2015 8:06pm
Yep, sounds about right, there is the outside chance it is the immobiliser, they can fail like that but usually you don't get the beeping with it... new switch should sort it... Thumbs Up Pete
Post #360557 5th Dec 2015 8:13pm
steadyaway
Cheers Pete a second opinion on the lines of my thinking is good news. Shame it won't start as I was in your neck of the woods today but had to come in the wife's. Didn't fancy being stranded if it failed.
Post #360562 5th Dec 2015 8:30pm
steadyaway
New switch fitted (thanks Dan@Duckworths), and happy to report all is well.
Post #362957 19th Dec 2015 5:54pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
Goodo! Thumbs Up
Post #362962 19th Dec 2015 6:40pm
