Home > Technical (L322) > newbie with probs
boatsandy1966
United Kingdom 2004 Range Rover Vogue SE Td6 Adriatic Blue
newbie with probs
Hi guys new member here . just bought 3/12/2015 a vogue td6 paid top money tbh but as dealer said was a great car with thousands spent full l/r history nearly mint had replacement recon gearbox and new toque converter at 125651 miles from Suffolk automatic transmissions . paid 9750 has just done 131300 odd mies now . Now heres my problem that I hope you nice guys and girls can steer me the way to go I found out 1 the sat nav didn't have a disc in fair play the dealer found one didn't stay in kept being rejected hes taken the unit out from boot and is getting another 2 the wingmirrors don't stay back he took me and car to land marques in hadleigh guy said spray with wd40 Now 3 the car has 5 times now gone into trans fail mode sticks in 3rd after 5-6 miles took back to dealer took me to land maques had diagonostic check couldn't find any probs apart from old codes I think he cleared codes was told battery even though good was at only 75% so advised charging over night of which I did went out to see family in herts after driving 20 odd miles bing trans fail again and also on way back after 10 ish miles on a120 doing 60 -65mph Now I'm hopeing you peeps can advise me what way to handle this problem ? Thanks to all in advance also noticed not sure if normal that the little red light by the p on gear shifter stays on after shutting and locking don't know if supposed to ???
Post #360541 5th Dec 2015 5:57pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Welcome - sorry to hear you are having problems.
Try and use some punctuation and paragraphs.
Makes your post easier to read and probably more likely to get a response. Thumbs Up Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #360552 5th Dec 2015 7:58pm
Red light stays on for 16 minutes after you turn off, then car goes to sleep...
Best way to "handle this problem" is to return the car to the dealer and get them to fix it...
If you use the search function you will find dozens of threads about it, sometimes it's a small simple thing sometimes it needs a new box...
And yes you did pay top money, at that price it should be mint with no faults at all...
Good luck.... Thumbs Up Pete
Post #360554 5th Dec 2015 8:01pm
Dolphinboy
Am I correct in Thinking Trans fail safe may be triggered by the gearbox oil heating up on account of a blockage in the lower part of the radiator? See if they will put a new radiator and oil cooler in.
Otherwise it sounds as if the new gearbox needs a Look at or a re-set?? (Please feel free to advise otherwise anybody?) Thumbs Up
Post #360561 5th Dec 2015 8:29pm
CS
You might find it useful to look at the Consumer Rights Act 2015, which is easily found by googling that title, in particular:
section 9 (test of satisfactory quality),
19 (rights of the consumer where the dealer is in breach of contract by supplying goods not of satisfactory quality)
20 (right to return the goods and get your money back)
22 (30 day time limit for return/refund)
23 (right to repair/replacement).
There is also a Citizens Advice item on this which might be helpful. Only Range Rovers since 1988
Post #360563 5th Dec 2015 8:45pm
boatsandy1966
opps sorry its quite hard to type into forum from a phone
Post #360566 5th Dec 2015 9:05pm
boatsandy1966
thanks for this I'm taking back Monday and going to see what the guy has to say tbh I'm losing faith in the car at the moment thought I was doing best paying top dollar for what looked a great car with known issue supposedly sorted how wrong was I !
Post #360567 5th Dec 2015 9:07pm
boatsandy1966
UPDATE car spent day with dealer and garage battery checked all fine came up with a code 5?? the gearbox rebuilders said if happens again after gearbox being reset to take to them and will replace a cable so fingers crossed will try today for a few miles then if needed a trip to Suffolk to gearbox builders it is
Post #361020 8th Dec 2015 10:16am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
yes, we had exactly the same problem a couple of years ago. Had the gearbox rebuilt at a cost of £3000 then a while after that went on a trip down to Cornwall. On the way back (about 10 miles from home) gearbox went into limp-home mode (wouldn't go over 3rd gear), turned out to be the bottom 6 rows of the radiator collapsed internally (known problem), radiator and trans oil cooler replaced and since then no problems!
Post #361067 8th Dec 2015 2:22pm
boatsandy1966
am off to Suffolk automatic transmissions tomorrow so fingers crossed will be sorted if not going to have to back the car and find another pain in butt that would be carless over Christmas not great with a disabled parent
Post #361987 13th Dec 2015 10:17am
miggit
My gearbox builder insisted that the radiator and gearbox cooler were changed, otherwise they would not warranty the work Shocked So it's a known fault Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #362013 13th Dec 2015 12:06pm
boatsandy1966
update ;;
well after taking a few extra hours on Monday after working 26 hrs straight I took rangie to Suffolk transmitions they say problem is slipping in 5th will have to be booked in took back to dealer he sorted a loaner that had half a field left in it doubtful mot !. had a moan gave me a Volvo 2007 is ok but not my rangie . texted dealer Friday rangie still in Suffolk . Bit gutted going away for chrimbo this week wanted to take rangie still no clue to when back cant go away without rangie as Volvo has 2 doors small boot needed 5 seats and big boot. Hoping I get rangie back or I loos deposit on hotel and the price of turkeys is frighting also cant seem to find good restaurant with any spaces left local dam I wish id never bought it ! happy chrimbo everyone !!
Post #362942 19th Dec 2015 4:53pm
